Bench top Dog holes
Forum topic by CEY posted 08-11-2017 05:02 PM 1126 views 0 times favorited 19 replies Add to Favorites Watch
View CEY's profile
CEY
7 posts in 387 days
08-11-2017 05:02 PM
I hope to finish up a new workbench for my shop this weekend. I want to drill some bench dog holes opposite my vise, but can’t figure out how to get them perfectly vertical when all I have is a hand drill.
I have a drill press, but can’t position the head down low enough to where the bit will drill below the base.
Any ideas?
Chuck in NV
19 replies so far
View bondogaposis's profile
bondogaposis
4727 posts in 2349 days
#1 posted 08-11-2017 05:10 PM
I used my plunge router w/ a 3/4” straight bit to start the holes then finished them with a spade bit.
-- Bondo Gaposis
Smitty_Cabinetshop
15351 posts in 2616 days
#2 posted 08-11-2017 05:14 PM
I’d suggest they don’t have to be perfect to work as holes for hold fasts or dogs, either one. I’m sure the holes in my bench top are not.
View onoitsmatt's profile
onoitsmatt
392 posts in 1174 days
#3 posted 08-11-2017 05:18 PM
+1 to what Smitty said. If you really want perfectly vertical, you could drill a perfectly vertical hole in some scrap using your drill press, then clamp that scrap to your bench with the hole in the scrap located where you intend to drill a hole in your bench. Use the “true vertical hole” in the scrap as a guide for drilling free-hand into your bench.
-- Matt - Phoenix, AZ
Smitty_Cabinetshop
#4 posted 08-11-2017 05:23 PM
^ That’s a fine suggestion!
View moke's profile
moke
1175 posts in 2774 days
#5 posted 08-11-2017 05:38 PM
I drilled my first bench with a plunge router ( as deep as it would go)...finished them through with a spade…..they are perfect and nice….it took me forever.
I drilled my second bench with a “General” company fixture for the front of a hand drill that looked like a plunge router…it was quicker but still a little labor intensive for me…I used a forstner bit.
My neighbor asked for my help and We used the drill “fixture from General” to drill a hole maybe an inch deep and finished it off by hand with a second drill and operator and it was much quicker! We used a couple of Deming 3/4 drills ( Deming drills are 1/2 shank…you can buy them individually).....I found that my spade bit was a little light of 3/4…enough so the dogs fit rather tight.
I believe that was almost as accurate if not just as accurate…As Smitty said…I’m not sure its that critical to be perfect. I also put a very light chamfer on with my colt pony palm router.
Just my .02
Mike
-- Mike
View jmartel's profile
jmartel
7891 posts in 2148 days
#6 posted 08-11-2017 08:02 PM
If anything, it’s preferred to have a ~2 degree angle pointing towards the vice.
You can also use a DIY drilling jig. Fasten 2 boards together at a 90 deg angle and put it on it’s side. Use the corner as a guide to drill straight.
View Redoak49's profile
Redoak49
3242 posts in 1986 days
#7 posted 08-11-2017 08:45 PM
I used a 3/4” anger type bit that was long. I drilled a hole in a 3” block of hardwood on my drill press and the used it as a guide.
View John_H's profile
John_H
173 posts in 1704 days
#8 posted 08-13-2017 06:43 AM
How much money do you want to spend :)
Lee Valley sells Dog Hole Bushings and Bits that aren’t too expensive
Another option – I use this method when I want to make a “MFT” style top
I bought a Festool MFT replacement plate to use as a ‘template’. (Since you have a drill press, you could make something with just a couple of holes)
I clamp the ‘template’ to my work surface and using a drill bushing I purchased from McMaster Carr, I drill out the majority of the hole (Festool holes are 20mm in diameter)
After drilling – this is all I have left to remove:
A router with a 1/2” flush cutting pattern bit (bearing on top) is small enough to fit down through the hole (I don’t plunge it because I don’t want to screw up my template) and easily removes the rest of the material
View HorizontalMike's profile
HorizontalMike
7757 posts in 2912 days
#9 posted 08-13-2017 11:23 AM
Another similar home made jig for hand drilling dog holes. Only had an 8in drill press at the time, that was much too small for such a large project:
. Notice that I labeled the measured hole distances for a more uniform look, when drilling them with a hand drill. V—below—V
View jonah's profile
jonah
1700 posts in 3296 days
#10 posted 08-13-2017 12:12 PM
There is no earthly reason why dog holes need to be straight in the first place, so don’t worry about it. Bench dogs or holdfasts work just fine in 87 or 93 degree holes.
View CEY's profile
CEY
7 posts in 387 days
#11 posted 08-13-2017 01:31 PM
There is no earthly reason why dog holes need to be straight in the first place, so don t worry about it. Bench dogs or holdfasts work just fine in 87 or 93 degree holes.
- jonah
Oh I guess I agree with that statement, but unfortunately I have a little OCD… LOL
View Ron Aylor's profile
Ron Aylor
2605 posts in 645 days
#12 posted 08-13-2017 01:53 PM
I did my dog holes like this … between 11:47 AM and 12:33 PM every day for 3 months … all holes are 88.569° to 92.368° … works just fine!
-- Ron in Lilburn, Georgia.  Knowing how to use a tool is more important than the tool in and of itself.
4985 posts in 2491 days
#13 posted 08-13-2017 03:34 PM
I’ve used a plunge router, but since I didn’t have a 3/4” bit that would drill holes, I used a 1/2” and then went back later with a fluted 3/4” to enlarge them. Took a while, doubt I’ll ever do that again. I bought the LV bushing for the last go around, and it really works well.
View Andre's profile (online now)
Andre
1830 posts in 1804 days
#14 posted 08-13-2017 04:12 PM
Tried all the above methods with varying success and ended up using a hand brace, quickest and as accurate as needed for my Gramercy holdfasts. Put in a row of Veritas Prairie Dog for the tail vise and really like them.
View cabmaker's profile
cabmaker
1730 posts in 2807 days
#15 posted 08-14-2017 10:56 PM
Hahahahaha!!!
- Ron Aylor
