Miter saw placement suggestions?
Forum topic by PNW_Steve posted 08-11-2017 04:40 PM 853 views 0 times favorited 9 replies Add to Favorites Watch
View PNW_Steve's profile
PNW_Steve
50 posts in 502 days
08-11-2017 04:40 PM
Hey Everyone,
I am building a new miter saw bench and am at a point where I need to finalize saw placement. The bench is 8’ long and I can place the saw at any point along that 8’.
I have it “mocked up” at 64” to the left and 12” to the right. See pic below.
Before I break out screws & glue I would like to hear from you all any suggestions regarding right/left location?
Thanks
S.
9 replies so far
View AlaskaGuy's profile
AlaskaGuy
4782 posts in 2509 days
#1 posted 08-11-2017 07:02 PM
since I work from both sides of the blade I’d put in in the middle. I leave the glue out of it in case you want to move it later. Screw alone with hold just fine.
PNW_Steve
#2 posted 08-11-2017 08:05 PM
since I work from both sides of the blade I d put in in the middle. I leave the glue out of it in case you want to move it later. Screw alone with hold just fine.
- AlaskaGuy
Thanks AlsakaGuy,
I have never had a dedicated miter saw bench before and simply looked at others examples online.
I never really work fro the right side of the saw. Not for any particular reason. Just a habit I developed. Maybe I should try working from both sides??
PNW_Steve
#3 posted 08-11-2017 08:49 PM
Can anyone tell me what the bed height is on a DeWalt DWS-780 is?
View builtinbkyn's profile
builtinbkyn
2653 posts in 1140 days
#4 posted 08-11-2017 08:52 PM
If you have more room to the right of the station, I would leave it as you have it. Placing it in the middle will limit you on the left side of the blade. You can always make a removable outrigger or use rollers on the right side for longer pieces.
-- Bill, Yo!......in Brooklyn & Steel City :)
PNW_Steve
#5 posted 08-17-2017 02:13 AM
- builtinbkyn
I have about 4’ to the right of the end of the table where I can set a roller stand if needed. It would be in the way if I left it there but for occasional use I think it would not be a problem.
I have assembled it in the configuration shown in the picture using only screws. I can change it later if I don’t like it.
Thanks for the input.
S.
View Dave1948's profile
Dave1948
1 post in 615 days
#6 posted 08-19-2017 07:36 PM
Just a thought. When I built my miter saw table (very similar to yours), I mounted the saw on a sheet of MDF and mounted a T-Track down the center of the table. I mounted a T-Bolt on each side of the saw so when installed, I can slide the saw along the track so it can be at any point on the table. I also mad two supports that are mounted in the T-track so I can have support anywhere I want. Just a thought.
View Andybb's profile
Andybb
1492 posts in 803 days
#7 posted 08-19-2017 09:10 PM
Actually a good idea! Always thought that when I built one it would be in the middle but I too always work from the left. It also gives you a nice little work surface which you can never have enough of.
-- Andy - Seattle USA
View TaySC's profile
TaySC
270 posts in 533 days
#8 posted 08-19-2017 09:15 PM
Like you, I also work mainly from the left side for whatever reason. I like the current placement.
What I would consider doing, however, is building a dropleaf for the right side so you can pull it up when needed to gain a few feet on that side.
View JackDuren's profile
JackDuren
388 posts in 1159 days
#9 posted 08-19-2017 10:42 PM
How far left or right?
