Has anyone tried staining Poplar ?
Forum topic by MrWoody posted 637 days ago 6242 views 0 times favorited 13 replies Add to Favorites Watch
View MrWoody's profile
MrWoody
283 posts in 666 days
637 days ago
Topic tags/keywords: question finishing
I’ve glued up some panels for a project for my daughter. I used polar because she said she was/is going to paint it, but they have beautiful grain patterns.
If it can be stained, I’m going to try her into not painting.
I would try some scraps, but I don’t seem to have any stain here and I can’t see any point in buying some if I’m not going to use it.
TIA
-- If we learn from our mistakes, I'm getting a fantastic education.
20519 posts in 713 days
637 days ago
Poplar can be stained but you will end up with some green areas initially. These will fade to a nice brown with time. So if you can be patient with the piece it will end up a nice shade with time.
I stained all my poplar doors and trim with Minwax Early American and finished them with poly. I really don’t know how long it took since I wasn’t really aware of when the change occurred. I just realized that the greenish tint on some of the panels had simply transformed into a nice brown one day.
Here are some photos:
http://i267.photobucket.com/albums/ii303/sbryan55/LumberJockPictures028.jpg
http://i267.photobucket.com/albums/ii303/sbryan55/LumberJockPictures029.jpg
http://i267.photobucket.com/albums/ii303/sbryan55/LumberJockPictures030.jpg
In the third photo the door on the right is a 6 panel pine door. I was trying to get the poplar and pine to match as closely as I could.
MrWoody
637 days ago
Gorgeous, from the pictures they seem to match.
I’ll tag this and show it to my daughter.
Thanks
View Critterman's profile
Critterman
546 posts in 701 days
637 days ago
Woody, I’ve played with staining it and you have to be careful. Poplar can get blotchy on you so i’d do a seal coat before staining. I haven’t discovered a way to tell where and when it will happen, but I’ve had some pojects that do and some that don’t. Better safe than sorry. Just a heads up.
-- Jim Hallada, Chesterfield, VA
MrWoody
637 days ago
Thanks for the heads up.
View CoolDavion's profile
CoolDavion
213 posts in 716 days
637 days ago
I’ve stained Poplar for this project . I used MinWax brand PolyShade.
Lowes (and probely other stores) sells little 1/2 pint cans, so you can get a little bit of stain without a major investment.
-- don't sweat the petty things and don't pet the sweaty things
View TampaTom's profile
TampaTom
69 posts in 645 days
637 days ago
Either way, I’d recommend getting some Zinnser Seal Coat and cut it half and half with denatured alcohol – wipe that on as a seal coat and sand it down with fine grit paper before you stain. That should control the blotching….
-- Tom's Workbench - http://tomsworkbench.com
MrWoody
637 days ago
Thanks guys, I’ve talked to my daughter and we’re going to give staining it a try.
Tampa Tom:”I’d recommend getting some Zinnser Seal Coat”.
I suspect that I won’t find that around here, is it similar to shellac?
View Ampeater's profile
Ampeater
200 posts in 639 days
636 days ago
Zinnser Seal Coat is a 2 lb cut of dewaxed shellac and is available at most big box stores.
-- "A goal without a plan is a wish."
View Fuzzy's profile
Fuzzy
14 posts in 880 days
636 days ago
Several years ago, I made a bunch of Poplar door casing, chair rail, and baseboard to re-do my in-laws house. We did a LOT of research and wound up using WOODKOTE bran gel stain. I’d have never thought Poplar could look so nice. This stuff was great and required no sealing or pre-stain conditioner. Check into it .. .. I think you will be glad you did.
I know there are now lots of gel stains on the market, but I keep going back to what I know to work well for me .. .. and this stuff gets my vote.
View jcees's profile
jcees
553 posts in 690 days
636 days ago
Ditto on the SealCoat. I use it straight up, either by brush or sprayer. A light sanding and then I squirt water based dyes out of a bottle sprayer. Let it dry, scuff sand then spray on another light coat of SealCoat then finish with either poly or lacquer. Voila! Note: if you use lacquer, you can skip the last scuff sanding.
I struggled for the first half dozen years of my woodworking life by experimenting with all manner of finishing schedules and the above is what I’ve settled on and have absolutely no qualms in recommending. It is easy to amend, modify or reverse and never fails to impress. I know it sounds a bit too good to believe but it is a matter of keeping it simple rather than falling for some brewmaster’s alchemic secret formula. Although, a light dusting of pixie dust never hurts…
always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
View scottb's profile
scottb
3403 posts in 1218 days
636 days ago
I’d read that it can be stained or dyed to be a pretty good match to cherry. (for what it’s worth)
View Joe Lyddon's profile
Joe Lyddon
480 posts in 943 days
636 days ago
Tampa Tom,
That sounds like Knipfer’s Rude & Crude method! :) :D
View Justin's profile
Justin
37 posts in 648 days
636 days ago
Poplar, I have had luck staining it two ways. The first way was with a coat of shellac, then stained over it. Very good result. And I did noticed that in a short amount of time It had darkened to a more even color.
The other way I had luck and it took the stain very well was with Water based dye stain.
Justin
