Upper Wheel Removal for Ridgid BS14002
Forum topic by swampjack80 posted 01-12-2011 06:53 AM 1237 views 0 times favorited 2 replies Add to Favorites Watch
View swampjack80's profile
swampjack80
53 posts in 3072 days
01-12-2011 06:53 AM
Topic tags/keywords: question
The upper shaft-hinge broke on my band saw and I’m having a hard time getting the wheel off to get to it. Have any of you tried taking your upper wheel off of this saw? From all the research I’ve done it seems the nut should unscrew and the wheel and bearings should slide right off the axle/bolt that it’s mounted on. But when i turn the nut, the whole bolt turns so nothing gets loosened. So i tapped the bolt out of the shaft-hinge housing and removed the wheel with the bolt and bearings still intact. Now I can’t get the bolt out of the wheel. I’ve tapped it with a hammer and nothing. I’ll try to get some pics if I’m not describing this well enough. If anyone has this saw and knows what I’m talking about, please help. Thanks.
-- "I believe that our Heavenly Father invented man because he was disappointed in the monkey." - Mark Twain
2 replies so far
View William's profile
William
9949 posts in 2865 days
#1 posted 01-26-2011 05:41 AM
Photos may help.
Is there a set screw in the center section of the wheel?
I don’t have this particular saw. I have a much older Craftsman, but in addition to the nut and bolt that I think you’re describing, there is an allen head set screw that keeps it from moving. I guess this was an extra precaution. It might be something you want to look for on your though.
View jnesmith's profile
jnesmith
3 posts in 2701 days
#2 posted 01-26-2011 08:03 PM
I have that saw, and took the top wheel off a few days ago. The bolt came off easily, and the wheel slid right off the shaft. I have never experienced your particular problem.
Sorry I couldn’t help.
