Radial Arm Saw Return Devices - what's your opinion?
Forum topic by Underdog posted 08-11-2017 02:46 PM 1499 views 0 times favorited 10 replies Add to Favorites Watch
View Underdog's profile
1058 posts in 1964 days
08-11-2017 02:46 PM
What’s your opinion on Radial Arm Saw return devices (such as the Delta 33-723)? Are they a needed safety feature? Or are they dangerous addition?
If you have more than an opinion, ie. facts to share, then please, let’s have it.
Whatever you have to say, good, bad, or ugly, I’m interested.
-- "woodworker with an asterisk"
10 replies so far
4905 posts in 2422 days
#1 posted 08-11-2017 03:40 PM
I’ve used an RAS regularly since the very early 80s, and have never had such a device. I just don’t see them as being of use. Since I’ve never had one I have no idea of how that might affect safety. I can’t imagine it making the saw safer, but I could see it being unsafe (just a swag). I do know a fellow that made his own by putting a weight on the end of a rope (maybe it was a steel cable) that went around some pulleys and would return the carriage to the stopped position. Everytime I asked why that was so important to him, I wouldn’t get a real concise answer.
View TungOil's profile
863 posts in 424 days
#2 posted 08-11-2017 07:07 PM
I agree with Fred. the RAS has been in my workflow since the ‘70’s and I see no need for such a device. I’d rather NOT have the saw move on it’s own actually.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Smitty_Cabinetshop's profile (online now)
15244 posts in 2547 days
#3 posted 08-11-2017 07:20 PM
I have a RAS without a return device. My thought is, anything that would lull me into thinking I could safely let go of the RAS handle while the saw is still running is a very bad thing. As it is, I very deliberately return the saw to the backmost position before releasing it and reaching straight for the power switch. Maybe a return spring would keep it from moving at that point? But I have the detent turn screw ‘friction fit’ alongside the MBF’s carriage head to keep it stable.
6467 posts in 2128 days
#4 posted 08-11-2017 07:28 PM
Obviously not dangerous, or Delta would not be selling them… but they aren’t for safety either. According to Delta, it helps “speed up production”, although how it helps speed things up or by how much is not really qualified. I would not want one, as I don’t really see a need for it – And at almost $200, I am not going to get one just to try it out :)
View jbay's profile
2137 posts in 828 days
#5 posted 08-11-2017 09:03 PM
I had one on my 16” RAS. I used the return spring and cable until it broke.
I thought it was nice not having to push the heavy cartridge back to it’s starting position.
The spring cable nicely balanced the weight. It never did pull the saw back by itself.
I would put one back on if I ever take the time to order another one.
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
View eflanders's profile
268 posts in 1779 days
#6 posted 08-12-2017 04:54 PM
I added one to my saw by adding a pull and a counter weight. The trick is in getting the right weight. I like it and wouldn’t think of removing it.
View ohtimberwolf's profile
760 posts in 2281 days
#7 posted 08-13-2017 01:25 PM
I’m with smitty on this. I NEVER let go of my saw and always have a firm grip on it while expecting that anything could happen at any moment. I believe that has helped me have zero problems ever since I first bought the saw save one instance early on when I made the mistake of being too lax at thinking of what could or might happen.
I use my radial arm saw a lot.
-- Just a barn cat, now gone to cat heaven.
View Nubsnstubs's profile
1265 posts in 1659 days
#8 posted 08-13-2017 02:34 PM
I worked in a shop in the 70’s that had 8 RAS’s set up for different cuts. Each one had a 5 lb piece of lead attached to a line that went through a pulley, and then to the motor. It kept the saw back up against it’s stop, and when making a cut, it kept the saw from over cutting or climbing if that’s the proper term. It worked great for those applications.
When I started my own cabinet/furniture shop in ‘78, I never had the desire to make a RAS part of my equipment because slide boards were more accurate using a table saw. I’ve been given several RAS’s, and as soon as I get one, I give it to someone else. Don’t like them…......... Jerry (in Tucson)
-- Jerry (in Tucson)
View JackDuren's profile
388 posts in 888 days
#9 posted 08-13-2017 02:43 PM
I see nothing wrong with it for production use…A plus…
#10 posted 08-15-2017 12:48 PM
Assessments of this accessory are mixed. Not surprising given the diversity here.
I’m wondering though, if there are any objective criteria either way to support these conclusions?
I was instructed to install them on our Radial Arm Saws by the insurance company. I’m sure it’s a safety driven thing, but I wonder if they have any objective criteria for insisting we have them?
