How do I make or where do I buy Clock faces?
Forum topic by Alongiron posted 01-12-2011 03:03 AM 11010 views 4 times favorited 5 replies Add to Favorites Watch
View Alongiron's profile
Alongiron
647 posts in 2690 days
01-12-2011 03:03 AM
Topic tags/keywords: clock making question
I am new to Lumberjocks and am looking for some help. I am a woodworker that enjoys making clocks, I have purchased paper faces and/or printed some on my computer but I am looking to get into making or purchasing Hammered Copper Clock faces and dials. I have noticed here in alot of projects some beautiful clocks with Copper faces and dials. Can someone point me in the right direction? Thanks for helping out
-- Measure twice and cut once.....sneak up on it! Steve Lien
5 replies so far
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6940 posts in 3431 days
#1 posted 01-12-2011 03:36 AM
http://www.steebar.com/Inserts.html
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
View Popsnsons's profile
Popsnsons
387 posts in 2978 days
#2 posted 01-12-2011 04:09 AM
http://www.klockit.com/default.aspx?ksc=03O01 would be another alternative.
-- Pops ~ In So Cal...
View superstretch's profile
superstretch
1531 posts in 2690 days
#3 posted 01-12-2011 05:40 AM
Saw some in Woodcraft last time I stopped in
-- Dan, Rochester, NY
View William's profile
William
9949 posts in 2839 days
#4 posted 01-12-2011 06:52 AM
http://www.wildwooddesigns.com/Clock-Inserts-C2.aspx
http://www.cherrytreetoys.com/Clock_Dials_C72.cfm
http://www.scrollerltd.com/products.asp?dept=31
http://www.woodenteddybearonline.com/mm5/merchant.mvc?Screen=SFNT&Store_Code=EM3965
These, and the one’s listed before my post, are all excellent places to order clock parts. You can order clock dials, complete inserts, many different style clock hands, and pretty much any clock part your mind can fathom.
Personally, when I build clocks, I want as much of the clock as possible to be made by me. So, I pick up battery operated clock movements from the craft section and wal-mart and make my own clock faces. I just draw whatever clock face I think will look good on a particular clock, and cut it out on my scroll saw. You can make them as simple or as elaborate as you want. I’ve always made mine out of wood, but with the right blade you could cut them from copper sheets, thin aluminum stock, pretty much anything thin enough to be cut on the scrollsaw, or whatever method you choose. I made a clock face out of metal flashing material one time (the type you use for flashing around chimneys when roofing) just to see if I could do that. I never actually put it on a clock though. I just drew out my design on a piece of 1/4” plywood. I sandwiched the metal between that piece of ply and another and cut it out on a scroll saw.
One of the simplest clock faces I done was just numbers. I drew all twelve numbers using stencils and cut them with a scroll saw. After cutting them I just glued them onto my clock in the right positions. I’m not good at keeping things like that straight. So, before gluing them on, I put in the clock movement, installed the hands, and rotated the clock through all twelve hours, marking the twelve places where the hour hand pointed to each time the minute hand reached the twelve o’clock position.
Another variation of that is simply two circles. The size of the circles will depend on the length of the clock hands and the size of the numbers you want in it (using stencils or your own drawings, it’s up to you). Measure everything so that the minute hand will fall on the outer edge of the largest circle, or in the middle of the two circles, your choice. Lay out your numbers so that the top and bottom of each number just touches the outer and inner circles. Then cut out. Simple, but nice looking clock face.
The ideas are endless.
Now if you want a real fancy looking face, here is one of my favorites: http://www.wildwooddesigns.com/4-Quartz-Clock-Inserts-C35.aspx
View Gator's profile
Gator
383 posts in 3672 days
#5 posted 01-12-2011 06:55 AM
I bought mine from Lee Valley.
Gator
-- Master designer of precision sawdust and one of a kind slivers.
