Question about project task lists...
Forum topic by RobH posted 01-12-2011 12:59 AM 1453 views 0 times favorited 13 replies Add to Favorites Watch
View RobH's profile
RobH
465 posts in 4045 days
01-12-2011 12:59 AM
Hello all,
I am getting back to woodworking after a well-needed little bit of time off. I have several projects from the wife stacked up and one in progress. Every project I do, I go through and make a task list so I can identify and make use of efficiencies such as table saw and router setups. I will admit that I over-plan my projects.
Question for everyone is, do you make task lists for your projects, and how do you keep up with them?
Thanks in advance,
Rob Hix
-- -- Rob Hix, King George, VA
13 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3557 days
#1 posted 01-12-2011 01:14 AM
Not often, but once in a while if there are many operations and if sequence is critical. It’s a real bummer to get something glued together and find out that you forgot something.
-- Joe
View Gregn's profile
Gregn
1642 posts in 2979 days
#2 posted 01-12-2011 01:36 AM
I have a terrible memory so I have a 30” x 30” wet erase sheet that I use to write things down so I don’t forget something.
View Cliff De Witt 's profile
Cliff De Witt
130 posts in 2688 days
#3 posted 01-12-2011 07:54 PM
I use a spreadsheet that I keep on my iPod Touch. Change the cell color as I go along, make necessary changes and then save the sheet to dropbox so I will ALWAYS have a copy if I ever get back there again….....What too much??
-- Trying to find an answer to my son’s question: “…and forming organic cellulose by spinning it on its axis is interesting, why?”
View lew's profile
lew
12056 posts in 3751 days
#4 posted 01-12-2011 09:34 PM
Rob,
Nice to see you are back and heading into the shop!
I wish I was organized enough to even think of planning ahead!
Lew
View Napaman's profile
Napaman
5526 posts in 4073 days
#5 posted 01-17-2011 02:32 AM
1st things 1st…YAY on the shop time…
Lists? yes…sometimes on longer projects…like on my sail boat I find myself making smaller lists for the stages I am on especially since I am going off a book of detailed plans…
-- Matt--Proud LJ since 2007
View MrDan's profile
MrDan
205 posts in 3283 days
#6 posted 01-17-2011 02:42 AM
I usually make a procedure list before I start cutting anything, but once I start, I usually find that I overlooked a step here or there and have to add that step back into my list. I use pencil and notebook with lots of space between steps for notes or forgotten steps. Then after the project is completed I save the list so in case I want to make another one in the future, I don’t have to “re-invent the wheel”.
View NBeener's profile
NBeener
4816 posts in 3170 days
#7 posted 01-17-2011 03:09 AM
Right now, the first and only thing on my Project List is “Make a Project List” ;-)
For those who get buy without notes … more power to ‘em !
I’m a big fan of notes. The more I think about a project before I dig in … the smoother the project goes. Odd, huh ?
And … another round of applause for more shop time !
-- -- Neil
View brianinpa's profile
brianinpa
1812 posts in 3719 days
#8 posted 01-17-2011 03:21 AM
Task list? I happy enough just to pick up where I left off and who knows maybe I’ll go a different direction than I originally planed.
View William's profile
William
9949 posts in 2838 days
#9 posted 01-17-2011 04:21 AM
The only “step” I have on any project is to put on the coffee and pick out the tunes every day that I go into the shop. After both the coffee pot and the stereo is going, I just go with the flow from there. No lists. No plans. When all the saw dust is cleared, sometimes I’m as surprised as anyone else is.
NBeener
#10 posted 01-17-2011 05:49 PM
If I had to guess, I’d guess that newer woodworkers are probably more likely to use lists (or written plans—in effect, the same thing) than seasoned, experienced Jocks.
I could be wrong, of course, but … that would be my guess.
I think it’s probably pretty comparable to cooking—at first, you follow recipes. Then, you learn—over time—what works well, together, and start winging it.
May I live long enough to get to THAT phase :-)
-- -- Neil
View miles125's profile
miles125
2180 posts in 4001 days
#11 posted 01-17-2011 05:53 PM
I make running list of what not to forget when i go to the %$#@^& Home Depot. Lol
-- "The way to make a small fortune in woodworking- start with a large one"
View steliart's profile
steliart
2595 posts in 2684 days
#12 posted 01-17-2011 06:57 PM
My wife says that I need a new memory card as I keep forgetting.
So yes I do plan, list and execute otherwise I’ll forget something that will prevent me to continue what I do unless I go and pick it up. Also always have my laptop with me when I’m working to follow or even make slight changes as I go with my plan.
A good idea will be to have a big writing board in the shop so that you can write down notes and things to do.
-- Stelios L.A. Stavrinides: - I am not so rich to buy cheap tools, but... necessity is the mother of inventions
View DebsWorkshop's profile
DebsWorkshop
1 post in 2092 days
#13 posted 08-30-2012 01:14 AM
As a matter of fact I use a task list and a flow chart for bigger projects. The list serves the purpose of allowing me to calculate the amount of lumber needed up front and keeps me on track as I go. I use a flow chart to itemize my tasks for bigger projects. I was taught to do this by a professional cabinetmaker who used these tools in his day to day work. I figured if it was good enough for him, maybe I should adopt it.
-- Deb's Workshop, http://www.woodworkingtipsforwomen.com
