flooring for a workshop
« back to Coffee Lounge forum
Forum topic by theshed posted 08-11-2017 12:29 AM 969 views 0 times favorited 7 replies Add to Favorites Watch
View theshed's profile
theshed
15 posts in 376 days
08-11-2017 12:29 AM
Starting a new build for my workshop. Any flooring recommendations to go over the concrete?
7 replies so far
View Gilley23's profile
Gilley23
489 posts in 467 days
#1 posted 08-11-2017 02:15 AM
Epoxy it and never worry about it again.
View GR8HUNTER's profile
GR8HUNTER
4355 posts in 797 days
#2 posted 08-11-2017 02:37 AM
epoxy will also act as an insulator and help keep humidity down lower then with out :<))
Smitty_Cabinetshop
15443 posts in 2703 days
#3 posted 08-11-2017 12:39 PM
Wood. You won’t regret it. Ever.
View bonesbr549's profile
bonesbr549
1569 posts in 3152 days
#4 posted 08-11-2017 12:51 PM
Like others seal it, with an epoxy. However, If you want to spend a lot of time there consider another flooring. My knees ache from long hours on concrete.
GR8HUNTER
#5 posted 08-11-2017 02:17 PM
- bonesbr549
have you considered anti-fatigue mats ?? :<))
View unclearthur's profile
unclearthur
182 posts in 1873 days
#6 posted 08-12-2017 08:13 AM
I used Dri-core subfloor panels and just screwed 1/2” plywood on top of them, then added a couple coats of varnish. Gives insulation value (warm), built in vapor barrier, soft under foot and the ply gives cheap wood flooring which looks OK for a shop. If a section gets damaged, its cheap and easy to replace.
View corelz125's profile
corelz125
476 posts in 1061 days
#7 posted 08-15-2017 12:40 AM
Looks like it’s good enough for someone’s paws
