Sharing insight into shoulder cuts on dovetails
« back to Joinery forum
Forum topic by Matt Vredenburg posted 08-10-2017 09:05 PM 2274 views 0 times favorited 13 replies Add to Favorites Watch
View Matt Vredenburg's profile
Matt Vredenburg
189 posts in 3438 days
08-10-2017 09:05 PM
Topic tags/keywords: trick joining tip question
I have heard and read information about shoulder cuts on your tails for dovetails. I can’t find much information on what to do. I cut my dovetails by hand and would love to learn more about how to use shoulder cuts that help hide the inside joint. The master woodworker that mentions this a lot is Steve Latta.
Please share any insight and your learnings so I can start to leverage this additional technique.
-- Matt, Arizona
13 replies so far
View Aj2's profile
Aj2
1426 posts in 1822 days
#1 posted 08-10-2017 10:01 PM
Are you have trouble with cut on the tail board that’s shows on three sides?
Sometimes I just use my Dt saw to make this cut if I’m not feel 100 accurate I will cut on the waste side of the line and clean it up with a chisel.
The tail board is the one that get a scribe line all the way around all four sides.
-- Aj
View CL810's profile
CL810
3797 posts in 3012 days
#2 posted 08-10-2017 10:08 PM
Watch David Barron’s videos on YouTube. Also, make a paring jig.
-- "The only limits to our realization of tomorrow will be our doubts of today." - FDR
Matt Vredenburg
#3 posted 08-10-2017 11:57 PM
Thanks for your reply’s. I am pretty good at cutting dovetails by hand (the last ones are normally my best ones), however, Steve Latta recommends cutting a shoulder on the inside of the dovetail pins (i think?) which cleans up the inside of the drawer and I assume covers up an fit issues (sometimes I can see my saw cuts on the inside).
I will check out David Barron’s video as well. Thank you!
-- Matt, Arizona
View Aj2's profile
Aj2
#4 posted 08-11-2017 01:38 AM
Oh yes I think I know what your taking about some woodworker like to have a shallow rebate on their half blind tail board.
Ive done once or twice its a extra step not needed.
-- Aj
Smitty_Cabinetshop
15368 posts in 2642 days
#5 posted 08-11-2017 03:19 PM
Chris Schwarz does this with a Veritas skew.
http://www.popularwoodworking.com/techniques/joinery/handplanes-and-dovetails
View dbeck's profile
dbeck
65 posts in 383 days
#6 posted 08-11-2017 04:18 PM
Thanks for posting that link Smitty, it really helped me understand better.
Smitty_Cabinetshop
#7 posted 08-11-2017 04:22 PM
No problem at all.
If you try it, the tool’s gotta be incredibly sharp. I tried it with a sharp #78, no go. Also, it’s gotta stay 100% level in the cut and not tear cross-grain. There’s certainly a learning curve to it; one that I’ve not opted to climb. Kudos to those that do, though.
View splinter1000's profile
splinter1000
13 posts in 1507 days
#8 posted 08-11-2017 08:07 PM
Rob Cosman sometimes does this also. You can see how here:
https://www.youtube.com/watch?v=hIkwZFBbPHo
Cheers
Matt Vredenburg
#9 posted 08-12-2017 06:07 AM
Smitty, thanks for sharing Chris’ article. I probably have that one, but it’s a stack of 10 years of magazines I have in my shop.
What Chris covers in the article is exactly what I was looking to do. Now I need to go try it out this weekend.
-- Matt, Arizona
Smitty_Cabinetshop
#10 posted 08-12-2017 02:22 PM
^ Pictures or it didn’t happen. :-)
View pintodeluxe's profile
pintodeluxe
5702 posts in 2837 days
#11 posted 08-12-2017 06:06 PM
I don’t use shoulders on dovetailed drawers, but find them extremely useful in case construction. The top rail of a cabinet is often joined to the case sides with a lapped DT joint. Cutting a shallow shoulder on the underside of the lapped DT helps with aligning the parts, and prevents racking too.
View TheFridge's profile
TheFridge
9606 posts in 1510 days
#12 posted 08-12-2017 06:23 PM
Yep. Just remember to do it before you cut tails. Otherwise you risk blowing out. Ask me how I know.
View lew's profile
lew
12101 posts in 3779 days
#13 posted 08-12-2017 07:36 PM
https://youtu.be/c01JexFF8_8
