Hosting Site for Images
« back to LumberJocks.com Site Feedback forum
Forum topic by Belle City Woodworking posted 08-10-2017 12:51 PM 657 views 0 times favorited 13 replies Add to Favorites Watch
View Belle City Woodworking's profile
355 posts in 4039 days
08-10-2017 12:51 PM
Hi All,
Does Photoshop no longer work for hosting images? Which image hosting site would you recommend?
Thanks!
John
-- Formerly known as John's Woodshop - and NO not the one from Ohio!
13 replies so far
View Cricket's profile
Cricket
2357 posts in 1614 days
#1 posted 08-10-2017 01:59 PM
Have you considered uploading your images to LumberJocks?
-- LumberJocks.com Community Manager
View GR8HUNTER's profile
GR8HUNTER
3993 posts in 735 days
#2 posted 08-10-2017 02:06 PM
- Cricket
YES ^^^^^ DITTO ^^^^^^ LISTEN TO THE SMART LADY^^^^^^^ :<))
Cricket
#3 posted 08-10-2017 02:14 PM
To upload your images to LumberJocks, simply click on the “img” button and the click “chose file”.
Browse to the image on your computer then click to select it and click “open”.
Once it has uploaded make sure to click to “Insert this image”.
It will then add the code to your content. Simply add what you want to say.
Cricket
#4 posted 08-10-2017 02:16 PM
End result of adding your image directly to LumberJocks.
View jmartel's profile (online now)
jmartel
7951 posts in 2172 days
#5 posted 08-10-2017 03:07 PM
Uploading to LJ’s doesn’t fill the area as well. Plus it has issues with rotation not being correct. Until the rotation issue is fixed, I don’t upload much here unless I have to.
I use Flickr personally.
View Rich's profile
Rich
2962 posts in 611 days
#6 posted 08-10-2017 03:14 PM
Uploading to LJ s doesn t fill the area as well. Plus it has issues with rotation not being correct. Until the rotation issue is fixed, I don t upload much here unless I have to.
- jmartel
I’ve uploaded probably hundreds of photos using the native LJ image upload and every one was oriented correctly. Some members have figured out the problem and posted instructions on how to prevent the sideways shot, so any photos that aren’t upright are due to user error.
I’m not saying there’s anything wrong with other hosting sites like Flickr though. If you’ve already uploaded it once, why do it again here?
jmartel
#7 posted 08-10-2017 03:26 PM
I ve uploaded probably hundreds of photos using the native LJ image upload and every one was oriented correctly. Some members have figured out the problem and posted instructions on how to prevent the sideways shot, so any photos that aren t upright are due to user error.
I m not saying there s anything wrong with other hosting sites like Flickr though. If you ve already uploaded it once, why do it again here?
- RichTaylor
Workarounds don’t work when you are only using your phone. If I’m using my phone, I’m not going through the double effort of putting it on my computer, then rotating on the computer, and then uploading.
It’s a bad site problem. You shouldn’t have to do the workaround.
View Rich's profile
Rich
#8 posted 08-10-2017 03:40 PM
It s a bad site problem. You shouldn t have to do the workaround.
- jmartel
I’m not going to argue with you on that. I’ve said before that the site should use the available EXIF data for orientation when photos are uploaded. I guess I lost track of the fact that the fixes members provide involve uploading to their computer first. It’s still no excuse for not doing the workaround and posting a sideways shot.
My workflow involves Lightroom for tonal adjustments, cropping, etc. Even if I took it with my phone, Lightroom Mobile passes it seamlessly to Lightroom, and from there I export it and post it here.
View torus's profile
torus
97 posts in 435 days
#9 posted 08-10-2017 03:56 PM
” If I’m using my phone, I’m not going through the double effort of putting it on my computer, then rotating on the computer, and then uploading.”
Do not take pictures with your phone in portrait mode ever and you should be OK.
-- "It's getting better..." - put this on my RIP stone!
jmartel
#10 posted 08-10-2017 04:00 PM
- torus
The problem is taking photos landscape orientation, not portrait.
View MarkSW's profile
MarkSW
6 posts in 313 days
#11 posted 08-10-2017 04:04 PM
Lets see if this worked
-- "If there are no dogs in Heaven, then when I die I want to go where they went." Will Rogers, 1897-1935
#12 posted 08-10-2017 08:55 PM
Thanks for all the info!!!
MrUnix
6758 posts in 2221 days
#13 posted 08-10-2017 09:08 PM
External hosting sites suck… and, as experienced with Photobucket, can go away – leaving the possibility of your pictures going away on this site (and any others where you have linked pictures) in the future. Holding your phone correctly to take a picture doesn’t seem like too much effort to keep them from going sideways.
