Caring for a cast iron table saw
Forum topic by agallant posted 01-11-2011 05:15 PM 2276 views 0 times favorited 18 replies Add to Favorites Watch
View agallant's profile
agallant
551 posts in 2788 days
01-11-2011 05:15 PM
So I am about to make the plunge in to a 3HP saw stop (lets keep the conversation away from it actually being a saw stop, if I was smart I would just say 3HP saw but I am kinda interested to see who ‘that guy’ is going to be). Currently I have a ridgid table saw with a granite top, very low maintance. I do not heat or cool the shop unless I am in it. What steps do I need to take to keep the top of my soon to be new saw in nice shape? How do I keep it from rusting etc?
-AG
18 replies so far
View Robinson's profile
Robinson
43 posts in 2594 days
#1 posted 01-11-2011 05:25 PM
It is hard to beat the old original Johnson’s Paste Wax.
-- Francis Robinson, Central Indiana, USA - - Shopsmith fanatic
agallant
#2 posted 01-11-2011 05:26 PM
Is i just that simple? Hell I use it on my granite top saw now to keep everything sliding nice and smooth.
-AG
View Dan's profile
Dan
3630 posts in 2782 days
#3 posted 01-11-2011 05:30 PM
I agree with the above. I just use Johnson’s paste wax. I apply a coat or two every few weeks or as needed. I have an older cast iron top saw that I had restored the top when I got it. So far I have had no rust show back up and the saw is in my garage, it gets wet.
Some people promote a spray on protector called Top Coat. I hear that works great also..
Don’t be afraid if you do get a few small spots of surface rust. Its rather easy to sand/buff out if you catch it early. Its bound to happen at some point.
-- Dan - "Collector of Hand Planes"
View wb8nbs's profile
wb8nbs
164 posts in 2594 days
#4 posted 01-11-2011 05:30 PM
I wax all my Iron tools with Butchers Bowling Alley Wax. Keeps the rust demon away and makes the surface Smoooooth. Just be sure to buff the wax good after a couple of minutes, lumps of paste wax get gummy and will rub off onto the wood interfering with some finishes. Do not use automotive wax or any other wax that contains silicone. That will surely screw up a wood finish.
-- The only difference between men and boys is the price of their toys.
View dbhost's profile
dbhost
5686 posts in 3134 days
#5 posted 01-11-2011 05:38 PM
Wax it, wax it, wax it… Not a table saw, but my bandsaw table paid a bit of a price for me not waxing often enough… Same with the lathe…
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
agallant
#6 posted 01-11-2011 05:40 PM
So how often do I need to wax it? Also is there an issue with not keeping a constant temp in the shop?
View DaddyZ's profile
DaddyZ
2475 posts in 2942 days
#7 posted 01-11-2011 05:44 PM
Here in OK we go from Below Zero to 100+, I only wax my saw top about 2-3 times a year, just when I am waxing something else & think it’s been a while since I did the saw.
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3085 days
#8 posted 01-11-2011 05:57 PM
I’ve used both wax and the spray on topcoat. I think the topcoat lasts a little longer but the wax is the cheapest. Sometimes low tech is the way to go!
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
View Jonathan's profile
Jonathan
2608 posts in 2952 days
#9 posted 01-11-2011 08:17 PM
I have used both Johnson’s Paste Wax and Top Coat. Between the two, I prefer the Top Coat. With that being said, I am going to be buying a new tablesaw soon, as I’ve sold my Powermatic 64A.
I will probably use the Top Coat or Renaissance Wax on the new tablesaw. The Renaissance wax is supposed to be much longer lasting than the Johnson’s. Yes, it’s more expensive, but you only need a little bit of it. Just build a couple of layers and you’re good. If you’re spending almost $3K on a TS, what’s a few dollars more for the protection going on top, right? The SawStop is powder coated too, so that will be good for most of the rest of the saw as far as longevity and not rusting.
Whatever you decide to go with, I second wb8nbs on making sure there is no silicone in the product as it’ll interfere with finishing the wood.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
Jonathan
#10 posted 01-11-2011 08:21 PM
Also, if you’re going to keep the saw covered, make sure the cover is breathable… basically don’t use a plastic sheet, or a plastic tarp, or anything lined with plastic.
View tyvekboy's profile
tyvekboy
1718 posts in 2915 days
#11 posted 01-11-2011 08:50 PM
I’ll second paste wax. I’ve heard you can also use what you use on your car …. if you ever polish that.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
dbhost
#12 posted 01-11-2011 08:54 PM
Tyvekboy. Car wax is one of the last things you would want to use. Most car waxes use silicone, which can get into the pores of the lumber and ruin a finish in nothing flat…
View crank49's profile
crank49
4029 posts in 2873 days
#13 posted 01-11-2011 08:55 PM
Johnsons for me. Besides, I like the way it smells. It works so good, I can’t believe it’s not banned on the left coast.
View live4ever's profile
live4ever
983 posts in 2912 days
#14 posted 01-11-2011 09:01 PM
Those beautiful cast iron tables lose that factory finish quick! I developed all sorts of scratches on mine (in the 7 months I’ve had the saw), and a few small rust spots here and there that I have had a very hard time removing. Sort of makes me want to bust out all the sanding and buffing pads, but I’m OCD like that sometimes.
I didn’t get the top coat on fast enough when I first got the saw – maybe it would have prevented the little spots. T-9 Boeshield + paste wax (Renaissance if you feel like splurging) is a oft-recommended way to go, and the route I utlimately chose.
View Tim Gates's profile
Tim Gates
38 posts in 2945 days
#15 posted 01-11-2011 09:02 PM
Boeshield keeps demon rust away just fine in Louisiana. The humidity here is unbelievable.
