Bending/Drying green "switches" to hold their shape
Forum topic by Glorfindel posted 08-09-2017 07:38 PM 971 views 0 times favorited 6 replies Add to Favorites Watch
View Glorfindel's profile
Glorfindel
4 posts in 407 days
08-09-2017 07:38 PM
Hello,
I am new to the forum and have a perhaps ridiculous question: I am bending small saplings and (mostly maple) switches into U and circular shapes and tying them with string. They’re not much bigger than hot dog roasting sticks. I’d like them to hold these shapes when I untie them without the use of fasteners, glues etc. They are small enough (1” diameter) that I can fit them into an electric kiln I use for ceramics. My question is, should i put them into the kiln at a specific temperature (it’s programmable) and hold at that temperature for a specific amount of time? My understanding is that if I dry them out, they’ll hold their shapes, but drying too fast and/or too hot will make matters worse.
Any advice on time and temperature would be greatly appreciated.
Thanks for your time,
Matt
View Loren's profile
10477 posts in 3764 days
#1 posted 08-09-2017 08:06 PM
Wood dries best at low temperatures
I think. Your kiln may not go that
low. All you want to do is evaporate
the water in the wood. I’ve dried wood
in a toaster over to shrink it at around
140 degrees I think. You can also build
a “shop oven” by insulating a box with
foil and putting a light bulb in there to
generate heat.
Glorfindel
4 posts in 407 days
#2 posted 08-09-2017 08:30 PM
Thanks,
My kiln can hold at that low of a temperature. I’m going to try 140 F for 48 hours and see how they feel. Any idea of how long I should keep them in? Again, they’re roughly the size of hot dog roasting sticks, but bent into curved shapes.
Matt
#3 posted 08-09-2017 08:35 PM
The only way to be sure is to use a
moisture meter. 48 hours sounds
like a good starting point.
Glorfindel
4 posts in 407 days
#4 posted 08-09-2017 08:44 PM
Thanks,
Any idea who might have a moisture meter on hand? I have a local kiln dried lumber place, maybe I’ll ask them.
Thanks very much for your input,
Matt
#5 posted 08-09-2017 08:56 PM
Glorfindel
4 posts in 407 days
#6 posted 08-10-2017 04:06 AM
Thanks for the link, I appreciate it! – Matt
