Scotch Brite Pads Vs. Steele Wool question
Forum topic by HuntleyBill posted 01-11-2011 03:05 AM 4521 views 0 times favorited 6 replies Add to Favorites Watch
View HuntleyBill's profile
HuntleyBill
109 posts in 3119 days
01-11-2011 03:05 AM
I have seen in many posts people recommending using scotch brite pads instead of 0000 Steal wool. I can’t seem to find anyone at the stores ( including Rockler ) who can tell me which color scotch brite pad in comparable to 0000 steal wool.
Is there such a thing? If so, what color do I need?
Thank you
Bill
-- If you think you can, or think you can't...your right!
View BlueMan's profile
BlueMan
1 post in 3021 days
#1 posted 01-11-2011 03:27 AM
White
View smitty22's profile
smitty22
714 posts in 2975 days
#2 posted 01-11-2011 03:31 AM
Best sources I’ve found are the automotive body shop supply stores. Any of them that sell OEM finishes will have the scotchbrite.
I find that I use the red more than the white, but do use both for both oil and lacquer finishes.
-- Smitty
View patcollins's profile
patcollins
1685 posts in 2894 days
#3 posted 01-11-2011 03:55 AM
According to this white is finer than 0000
http://www.ptreeusa.com/nonwoven.htm
View Dan's profile
Dan
3630 posts in 2909 days
#4 posted 01-11-2011 06:13 AM
I have also never tried white. The finest I have used is grey. I didn’t even know there was finer ones out there. I should look next time I am out. Thanks
-- Dan - "Collector of Hand Planes"
View TJ65's profile
TJ65
1378 posts in 3078 days
#5 posted 01-11-2011 06:31 AM
Never heard of this before- looks like I will be trying these out.
I find that the steel wool tends to leave its little fibres sometimes in certain projects. Usually in places hard to get into.
I just read that they are only good on stabalized wood, is that true?
Do you use them in the same manner as the steel wool?
-- Theresa, https://www.facebook.com/derrymore/
View onsecondthought's profile
onsecondthought
4 posts in 2080 days
#6 posted 03-28-2013 07:07 PM
White is equivalent to the 0000 steel wool. Jeff Jewitt has a good article in Fine Woodworking #159. I have used all colors of Scotch-Brite pads for years as well as steel wool. Experimentation is best on sample pieces. Steel wool will get into finer places than the white pads and the small fibers can be blown out with air. It’s best to use a block behind the white pads to avoid uneven rub out on flat surfaces. I may be mistaken but believe Klingspor Woodworking carries the white pads.
