| Forum topic by Shopsmithtom | posted 284 days ago | 177 views | 3 times favorited | 7 replies | ![]() |
284 days ago |
Topic tags/keywords: varnish finishing I’ve been wanting to try new finishes for my projects, and I remember reading somewhere about a mix of equal parts of boiled linseed oil, spar varnish, and turpentine. Does this ring a bell with anyone? Has anyone used this or any similar mix? Will polyurethane work instead of spar varnish? I’ve also heard of beeswax in a mix. Anyone know about this? -- Accuracy is not in your power tool, it's in you |
283 days ago |
Here is a recent discussion on a three part solution. Using Tung, Varnish, and thinner. I have not tried it, but favorited it. -- Stevethepeeve -- I'm no rocket surgeon |
283 days ago |
I mix my own finish, and i use it pretty much on everything i make now. It’s a Maloof style finish. -- Joey, Magee, Ms http://woodnwaresms.com |
283 days ago |
Hello SST; The mix I used was a 3 part mix of equal proportions: Just wipe//brush on and let sit a few minutes and then remove the excess with a cloth rag. Please pay special attention to those rags....I would place the rags in a metal garbage can and at the end of the day they would be already smoking. Burn your rags every day at the time you finish as these are highley combustible! Depending on the sheen you are after is how many coats you will apply…. Thank you. -- --frank, NH, http://frank.wordpress.com/ |
283 days ago |
Marc aka The Wood Whisperer advocates one part boiled linseed oil, one part varnish and one part mineral spirits. He may have said a different oil, but you get the idea. -- Eric at http://adventuresinwoodworking.com |
282 days ago |
I’ve also seen 1 part turpentine, one part beeswax and one part poly as a finish recipe… Haven’t tried it yet, but it might work… -- Tom's Workbench - http://tomsworkbench.com |
282 days ago |
There’s a little more discussion of a three part finish here at Chris Schwarz' personal site, in the most recent post. Also, our own Mike Lingenfelter has contributed a drawing there! -- Dorje (pronounced "door-jay"), Seattle, WA |
282 days ago |
The mix you describe is what’s known as a long oil in finish maker’s parlance. Easy to apply, easy to repair as long as you don’t try to “build” the finish as the film will be way too soft. It’s great for a lot of projects but not all. The spar varnish is already a long oil finish as it’s resistance to moisture and the blistering that might occur are circumvented via the built-in flexibility of the resulting film. The boiled in boiled linseed oil isn’t cooked at all but rather lets you know that metallic driers have been added to the raw linseed oil to promote a faster cure rate. The turpentine is just a thinner/solvent for the mix. A caveat: whenever you cut a finish with a given solvent, make sure you maintain that solvent in that mix. Don’t ask me how I know that, it’s too embarrassing. Anyway, what you propose is a soft finish that is easy to repair, not highly protective but adequate, never too shiny, smooth to the touch as it doesn’t get too much in the way of the wood and did I mention it was easy as heck to repair? Always, P.S. I use a mix of 1/3 each of pure gum turpentine, beeswax and boiled linseed oil for my wooden vise screws and to maintain my bench tops. It offers ease of use, adequate protection and the lovely amber glow that comes with the curing linseed oil. Hope this helps. -- "Imagination is more important than knowledge" -- Albert Einstein |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1363 |
| Become a sponsor |
1810 |
| Become a sponsor |
124 |
| Become a sponsor |
379 |
| Become a sponsor |
111 |
| Become a sponsor |
Woodworking Trade & Swap
252 |
| Become a sponsor |
Coffee Lounge
1020 |
| Become a sponsor |
LumberJocks.com Site Feedback
286 |
