laminate on furniture questions
Forum topic by plasma800 posted 08-09-2017 03:14 PM 551 views 0 times favorited 16 replies Add to Favorites Watch
View plasma800's profile
plasma800
10 posts in 474 days
08-09-2017 03:14 PM
I’m planning a credenza build.
The credenza is spec’d to be covered with Formica on the case. That would be both sides of each piece, including the divider between the drawers and the cabinet.
I’m pretty novice with laminate, even though I’ve used it in the past, but not on furniture.
I have a couple of decisions to make.
1) Substrate : Plywood, MDF, Particle Board or solid wood.
2) I’m thinking about the joinery. If I glue the case, I would need to be sure there was no laminate on the areas where the joints meet. I’m not 100% sure how to be so precise on the top and bottom.
I considered using rastex fasteners and dowels instead, but I’m concerned about racking.
I considered pocket screws, but this would require the formica go on last. I considered putting the pocket screws on the outside, then formica over.. but I can see where this might tough to roll.
I considered using contact cement at the joints, and just letting the formica of the top and bottom meet the raw edge of the sides along with dowels for alignment.
Looking for any and all suggestions about how to go about this.
16 replies so far
View LittleShaver's profile
LittleShaver
360 posts in 735 days
#1 posted 08-09-2017 05:40 PM
I have never done anything like this but…
Faced with this and the fact that you’re using sheet goods, I’d consider applying the Formica to the sheet goods as the first step. Then cut your pieces and joints. To assemble, use an epoxy glue to hold it all together.
I Hope someone with experience chimes in.
-- Sawdust Maker
View Loren's profile
10477 posts in 3763 days
#2 posted 08-09-2017 06:19 PM
If you use rabbets and dados, you should
be able to apply the laminate after and
trim flush using a bearing-guided trim
bit. Be sure to account for laminate thickness
when sizing the rabbets and dados.
You could consider Mod-Eez fasteners. They
can be used for butt joinery and are totally
concealed when assembled. http://www.mod-eez.com
View Bill_Steele's profile
Bill_Steele
403 posts in 1847 days
#3 posted 08-09-2017 06:32 PM
I’m not a pro at this either—that being said—I would rank solid wood as the last choice for a substrate—I think the others would be “flatter” and less susceptible to dimensional change based on humidity fluctuations.
I would try to wait until all the joinery and glue-up was completed before applying laminate (assuming that the shape of laminate pieces is square or rectangular). This is where the design would be important to know. I don’t know what those pieces of laminate would have to look like in order to fit or if there would be issues placing/gluing/trimming them after everything is glued up.
Perhaps applying laminate first and using loose tenons or some other type of “knock-down” fasteners (e.g. connector bolts/cap nuts) is the best strategy.
FWIW: I’ve applied laminate to only one side of some projects and so far (knock on wood) have not had warping issues because of it.
View jbay's profile
jbay
2582 posts in 1014 days
#4 posted 08-09-2017 07:10 PM
I would use shop grade maple or birch plywood for the substrate.
Laminate all your interiors first, cut your rabbets or dado’s and screw everything together from the out side.
After everything is built cover the exterior.
Cover the sides first, then the face, then top last.
If the back has to be laminated, cover it first, then the sides, face and top.
If you post a picture of what your doing we will be able to help better.
I’m just assuming seeing that I have no idea of your design.
plasma800
#5 posted 08-09-2017 08:31 PM
- Loren
I had considered this, even though it complicates the build a little and I wasn’t exactly going for the lines of a rabbet at the corners, however, with full overlay doors and drawers, they would be hidden anyway.
I’ve located a company here in town that sells TFL Panels, HPL panels in like.. a gazzillion different colors and textures. I’m considering buying the panels with the laminate already on them, then cut and assemble.. that might produce a much better result.. also this opens up a whole world of possibilities in modern furniture design for a small shop.
plasma800
#6 posted 08-09-2017 08:35 PM
It’s a really straight forward design… but the devil is in the details..
and likely I’ll go full 32mm on this thing, that will change the dimensions a little, but that’s ok.
the back would just be 1/2 or 1/4 ply
plasma800
#7 posted 08-09-2017 08:38 PM
oops post
plasma800
#8 posted 08-09-2017 08:42 PM
And Hittech makes these super cool VB connectors.. I might give them a try in a project like this or two..
https://www.youtube.com/watch?v=dQJHY9sTo8E
This video is boring as can be, but these guys look solid and don’t look bad after installation. I’m still really concerned with racking though on such a long carcass.
View jimbrown's profile
jimbrown
22 posts in 410 days
#9 posted 08-09-2017 09:19 PM
I’d use “pre-laminated” panels, you’ll live longer and you can control the joints.
-- JimBrown
#10 posted 08-09-2017 10:03 PM
As long as the back is securely installed
I don’t think it is likely to rack with KD
connectors, especially with that divider
and (I’m guessing) fixed shelf. Of course
the joints on thing like IKEA pieces fail
because the material is low grade, tears
out, and the cases just have the backs
affixed with a few screws.
View JackDuren's profile
JackDuren
388 posts in 1075 days
#11 posted 08-09-2017 10:19 PM
Why not laminate the interior pieces and screw together and laminate the outside..
plasma800
#12 posted 08-10-2017 01:51 AM
- JackDuren
I have no issue doing this, just trying to think through the details.
When you say screw together.. are you talking pocket screws… straight through butt screws… ?
Where’d you find those legs? I really like those.
plasma800
#13 posted 08-10-2017 01:53 AM
I don t think it is likely to rack with KD
and (I m guessing) fixed shelf. Of course
- Loren
I could, as stated, laminate the interior side, assemble with KD or rastex from the outside, the laminate the outsides.
This is where i get stuck.. there’s 50 ways to peel this onion …
Further, I’d like to make this repeatable. I live in an area where I think I could sell a few of these with a few options of color choices. And laminate makes so much sense for a dining room serving table.
I’ve been toying with the idea of changing the design to have a full length pull out tray just under to the top, and above the drawers for extra serving space. I know in our own dining area, we’d use it a lot to set out food for serving.
So the idea of tea jugs sweating on it, hot plates, hot pans.. laminate makes so much sense.
plasma800
#14 posted 08-10-2017 03:02 AM
- JackDuren
How are the corners on this case done? It looks like the corners might be mitered? ..
#15 posted 08-10-2017 03:03 AM
Confirmat screws are awesome for casework.
For what you’re doing the whole case could
be drilled for them in a few minutes using a
construction boring machine, but lacking that
the holes can be carefully be drilled by hand.
https://www.amazon.com/Confirmat-Screw-Two-Piece-Drill-50mm/dp/B003ASBBSE
