Creaping Router Bit
Forum topic by andy_P posted 01-10-2011 10:43 PM 3612 views 0 times favorited 19 replies Add to Favorites Watch
View andy_P's profile
andy_P
413 posts in 3404 days
01-10-2011 10:43 PM
I am using a Porter-Cable 890 router in a Rockler router table. I have run across this problem now and then and wondered if anyone else has experienced the problem.
Everything appears to be tight but yet I have ruined several pieces because the router bit travels up while making a pass and actually ends up breaking through the piece by the time you get to the end. I literally had to re-adjust the hight of the bit and almost over tighten the lever. The bit was stilll tight in the collet. I have found the only way to get around this is by tightening the locking lever to where it is almost too tight.
Any ideas or comments?
-- Wood is a gift from God/Nature that maintains its beauty forever via the hand of a woodworker.
19 replies so far
View DaddyZ's profile
DaddyZ
2475 posts in 3237 days
#1 posted 01-10-2011 10:54 PM
I have a porter Cable Router that done this, Solution New Collet the 1 in the router was Broke.
View papadan's profile
papadan
3584 posts in 3565 days
#2 posted 01-10-2011 11:00 PM
Place a small rubber o-ring on the bit shank to prevent inserting too far into the router collet. Too far in puts the collet on the tapered section of shank connecting the head. If your sure this is not the problem then replace the collet.
16280 posts in 4415 days
#3 posted 01-10-2011 11:04 PM
Is the bit moving in the collet, or is the height adjustment changing?
Actually, I just had a similar problem with my table-mounted Triton router. I’ve had the router for a couple of years, and always just set the bit height and went to town. No problem. Recently, I started having problems with the bit dropping lower during a pass. At first I thought the bit was slipping down in the collet since I never bottom out the bit when installing it. After monkeying around a bit, I realized I never bothered to use the locking lever on the back of the router. Duh….
It’s funny, though, that it worked fine for quite some time without using the lock lever before I started to have a problem.
View GMman's profile
GMman
3902 posts in 3894 days
#4 posted 01-10-2011 11:11 PM
I would say the lock lever is not tight enough.
After damaging a few pieces I now make sure my lock ever is tight.
andy_P
#5 posted 01-10-2011 11:13 PM
It is devinitely not the collet slipping. The hight adjustment is what is changing. I have a hunch from vibration, but you would think that it would be built to withstand that.
andy_P
#6 posted 01-10-2011 11:14 PM
I’ve tightened that lock lever so much that it is almost too hard to get closed alll the way. But, when I do that, it does seem to stop the problem.
View richgreer's profile
richgreer
4541 posts in 3271 days
#7 posted 01-10-2011 11:18 PM
I have the same router on the same table. I use it a lot and I have never had this problem. However, I am using a router lift (Woodpecker). Before buying the router lift I was bothered by how sloppy the lift mechanism in the base router was.
#8 posted 01-10-2011 11:19 PM
You may have already done this, but I would try cleaning all the mating surfaces thoroughly, wiping with mineral spirits. It could be that very fine dust is acting as a lubricant to allow the slippage.
View Steve Rathke's profile
Steve Rathke
27 posts in 3909 days
#9 posted 01-11-2011 05:18 AM
I had this happen on my porter cable 3hp motor. i added the rubber o-rings and clean the collet and cup out with compressed air. Also found some grease like stuff on some bits when they are new. its easy to wie clean with naptha – get it at the home center. clean, dry and o-ring fixed my porter cable bit slipping issue.
View Chelios's profile
Chelios
568 posts in 3262 days
#10 posted 01-11-2011 05:32 AM
If you overtighten the collet this can happen. You should buy a new one. They are cheap and it is worth it for your safety. Without seeing it, it is difficult to say for certain but even if this is not the issue with yours, don’t risk a bit travelling out of a router spinning at 30k rpm.
View DragonLady's profile
DragonLady
298 posts in 3203 days
#11 posted 01-11-2011 05:41 AM
I would replace the collet, as suggested. It’s a fairly cheap replacement, and worth it for safety.
If you are still having issues, then I would perhaps wrap the router motor in a layer of non-slip tape (or wrap a strip of that rubber mat stuff) around it and see if that helps. After cleaning everything very well, of course.
-- A woman's work is never done-but power tools help!
View ND2ELK's profile
ND2ELK
13495 posts in 3970 days
#12 posted 01-11-2011 06:10 AM
I would clean collet and bits as suggested and if this does not work, I would try a new collet.
-- Mc Bridge Cabinets, Iowa
andy_P
#13 posted 01-11-2011 07:44 AM
I can assure all of you that the bit is not slipping in the collet. I clean out the collet whenever I change a bit. Also, I maintain about 1/8 inch between the top of the collet and the base of the bit. When this does happen the bit is still in the collet where I set it. What moves is the entire hight adjustment to the router. It’s like someone is turning the adjusting knob while the router is running.
I will, however, do as many of you suggest and clean the entire router and check out the collet. I’ve got some dead time in the shop so maybe I will run it and run it and try and reproduce the problem on my terms.
View lanwater's profile
lanwater
3111 posts in 3130 days
#14 posted 01-11-2011 07:48 AM
It hapenned to me twice with the same router.
The first time I thought I did not tighten enough.
The second time I tought the hit shank is not upto snuff.
I bought a new collet.
-- Abbas, Castro Valley, CA
andy_P
#15 posted 01-11-2011 05:40 PM
lanwater:
Was the entire collet assembly creaping up or was the bit slipping within the collet?
