Corner Rounding
Forum topic by Glen posted 01-10-2011 10:10 PM 1110 views 0 times favorited 15 replies Add to Favorites Watch
View Glen's profile
Glen
116 posts in 2948 days
01-10-2011 10:10 PM
Topic tags/keywords: question
I am making a game that requires 24 identical 2 1/4 inch by 1 inch tiles. How do I round over each corner so they all are exactly the same?
Thanks,
Glen
-- Glen
15 replies so far
13594 posts in 3212 days
#1 posted 01-10-2011 10:25 PM
can you make a ‘log’
and round the corners with a router bit
then cut that into pieces
if you use something hard like maple
being end grain shouldn’t matter
View richgreer's profile
richgreer
4541 posts in 2945 days
#2 posted 01-10-2011 11:11 PM
David has provided the same advice I would offer.
View Loren's profile
9760 posts in 3519 days
#3 posted 01-10-2011 11:19 PM
template sanding. You can get a bearing-guided sanding drum
for a drill press or concoct a shop-made solution using a belt or
disk sander with a fence the template runs against.
View dbhost's profile
dbhost
5686 posts in 3103 days
#4 posted 01-10-2011 11:41 PM
David had the answer I would give you… Make a “log” with a roundover bit on the router table, then slice your pieces out of that.
Once they are sliced, if you need to round over the now flat sections, you can use a handscrew to hold the pieces as you run them through the router bit. NOT the easiest process, but doable…
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
View cabmaker's profile
cabmaker
1664 posts in 2680 days
#5 posted 01-10-2011 11:44 PM
Sounds to me like the log may not be what he is after as he has 24 2 1/4 individual pcs. I would use an inverted router with an overround (1/8inch R.).Inverted via router table or some means to support the router base. You ll need to take the piece to the cutter as that is pretty small to run the router on even with a small base.
#6 posted 01-10-2011 11:51 PM
we don’t know the thickness yet
1/4”
3/8”
1/2”
View Glen's profile
Glen
#7 posted 01-11-2011 12:04 AM
The thickness is 1/4”
-- Glen
#8 posted 01-11-2011 12:12 AM
if they have to be flat stock
and you have a router table and the 1/8th bit
do it with a fence close to the bearing
and stand them on edge
you can use a push block to keep then upright
are you going to round all corners
or just the outside ones
View Sarit's profile
Sarit
549 posts in 3011 days
#9 posted 01-11-2011 12:18 AM
Make jig that is a flat board with some thin strips around the perimeter to form an “L”. The area inside the L should be wide enough that when you lay the pieces in it, the pieces overhang the edge. The thin strips should be thinner than your pieces (in this case maybe 2”). Then you can line the pieces along the router table fence, place the jig on top, and us it to push several pieces through the router bit.
Once you do the short side of your pieces, you can rip the jig down to leave only 15/16th in in the inside area and then turn your pieces 90 degrees to route the long sides.
I hope this makes sense.
View Glen's profile
Glen
#10 posted 01-11-2011 12:32 AM
David,
I want to round the 4 outside corners.
-- Glen
#11 posted 01-11-2011 12:37 AM
how big a radius
View Glen's profile
Glen
#12 posted 01-11-2011 12:43 AM
1/8 inch radius would be enough.
-- Glen
View SteveMI's profile
SteveMI
1068 posts in 3165 days
#13 posted 01-11-2011 12:57 AM
I do this a lot, only with 4” by 10” maple that is 1/4” thick.
I just turn the individual pieces on on edge and pass the corner across the round over bit. Rotate the work 4 times and done. Use one with a bearing. I do the long flat edges first.
The 1/8” raduis on 1/4” stock isn’t doing much work so the effort is very minimal.
Steve.
#14 posted 01-11-2011 01:08 AM
here’s what i would do
i didn’t move my fence over for these pics
so just envision them closer to the cutter
this is the size of your part
and the orientation of it
and with a miter gauge and a backer board
the board will help the corner from splintering
(if you have a small clamp use it too)
run it thru and flip and turn for all 4 corners
hope this helps
or as stated above
you can stack them all into a corner and clamp the lot
and round them all together
View Glen's profile
Glen
#15 posted 01-11-2011 01:12 AM
Thank you David, the pictures really help me to understand.
Glen
-- Glen
