Need some advice on wood & design ideas for outdoor kitchen counter.
Forum topic by juicegoose posted 861 days ago 522 views 0 times favorited 6 replies Add to Favorites Watch
View juicegoose's profile
juicegoose
112 posts in 1230 days
861 days ago
The wife and I cook outdoors at least a couple times a week. We have always talked about how nice it would be to have a little sink outdoors to clean pans quick and also use for outdoor gardening. Well the porject gods blessed me with a nice little sink from the habitat store. My plan is to make a simple open structure around the sink with some wings on either side. Maybe a shelf under te sink for items but mainly leaving it wide open.
What would you guys think would bea good wood for this item
It would likely be exposed to water from being outdoors although the plan is to keep it on the porch.
I know teak would be great but the expense is a little much. Could I use something like oak and just put a good seal coat on it or what?
Also how would you guys recomend I mount the sink. Naturally I don’t think plywood would work very well or look good either. I had thought of something like laminate countertops but the substrate is junk and even gluing it to wood wouldn’t work well.
Any design Ideas or considerations I should take into consideration would be greatly appreciated. Thanks.
View Colin 's profile
Colin
93 posts in 979 days
#1 posted 861 days ago
White oak would be all right. That would probably be the least expensive option.
-- http://www.columbiawoodscreendoors.com
View levan's profile
levan
312 posts in 1147 days
#2 posted 861 days ago
I agree white oak
-- Lynn "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View dbray45's profile
dbray45
2018 posts in 945 days
#3 posted 861 days ago
White oak again. The reason for white oak is the same reason it is used in boats. The grain has a membrane in it that makes it almost water proof – one of the reasons that lumber mills don’t like it, its a pain to dry. It is hard, durable, and strong. If you put a good finish on it, it will look really good.
-- David in Damascus, MD
juicegoose
#4 posted 861 days ago
great thanks guys.
View childress's profile
childress
835 posts in 1710 days
#5 posted 861 days ago
Actually the least expensive would be a cedar or redwood. White oak is really good, but not as cheap as the other two, which could be bought at your local hardware store. At least that’s how it is around here…
-- Childress Woodworks
juicegoose
#6 posted 861 days ago
Thanks for the replies. I was wanting to get away from buying cheap lumber and just throwing something together but at the same time not dropping for teak. It seems that oak will give me some experience with hardwoods and at the same time not break the bank.
