Why some miter saws are loud?
Forum topic by Srini posted 08-08-2017 08:57 PM 607 views 0 times favorited 9 replies Add to Favorites Watch
View Srini's profile
Srini
29 posts in 900 days
08-08-2017 08:57 PM
Topic tags/keywords: question
I notice some cheaper miter saws are quite loud, while expensive (yellow brand and such) are lot quieter. Wondering what causes sound? Bearings or motor or drive system or any other sources?
9 replies so far
View TungOil's profile
TungOil
1006 posts in 615 days
#1 posted 08-08-2017 10:33 PM
You basically answered your own question- cheap tools are made from cheap components with less attention to quality and loose tolerances. As with many things in life, you get why you pay for in tools. This is why many folks prefer to seek out older machinery, especially for larger equipment like table saws and such. American made machinery from the 70’s and earlier, when restored, runs silky smooth and quiet compared to most of the consumer equipment available today (notable exceptions include the current European commercial machinery, but that’s out of most people’s price range unless you have a commercial shop).
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Aj2's profile
Aj2
1662 posts in 1918 days
#2 posted 08-08-2017 10:58 PM
The expensive Miter saws use muffler bearings good muffler bearing are expensive. :)
-- Aj
View jimintx's profile
jimintx
823 posts in 1704 days
#3 posted 08-08-2017 11:04 PM
- Aj2
har har ;-D
-- Jim, Houston, TX
View DS's profile
DS
2978 posts in 2540 days
#4 posted 08-08-2017 11:28 PM
Those would be the left-handed muffler bearings, right?
TungOil
#5 posted 08-08-2017 11:29 PM
yep, the ones in the aisle right next to the turn signal fluid.
View Gene Howe's profile
Gene Howe
10832 posts in 3548 days
#6 posted 08-08-2017 11:36 PM
Across from the tire size specific air exchangers. Ya know..from summer to winter blend.
View patcollins's profile
patcollins
1687 posts in 2985 days
#7 posted 08-08-2017 11:36 PM
Some of the noise is actually the sound of the electricity flowing through the coils in the armature of the motor. As the armature turns different sections of it get electrified causing the magnetic fields to build and collapse, this is what makes it turn. This electricity flow is not a constant level but pulses, a good portion of the sound is most likely a multiple of 60.
There is also the mechanical noise from the shaft in the bearings, any gears etc in the saw, the sound of the air displacement as the armature and blade move the air out of the way, and finally sound from the brushes of the motor not riding perfect on the commutator of the motor and arcing at the backside of the brush as it crosses to a different section of the commutator.
jimintx
#8 posted 08-09-2017 03:16 AM
Well, yeah, but what about the sonic disturbance of the teeth and gullets of the blade? Not to mention the effects of the teeth offsets, and the harmonics of carbide teeth versus plain steel teeth. Lots of factors influence the sounds produced.
-- Jim, Houston, TX
View splintergroup's profile
splintergroup
2253 posts in 1342 days
#9 posted 08-09-2017 03:50 PM
Spur gears versus helical cut.
