Leaving Batteries on Charger
Forum topic by DMiller posted 08-08-2017 06:46 PM 1157 views 0 times favorited 25 replies Add to Favorites Watch
View DMiller's profile
DMiller
379 posts in 498 days
08-08-2017 06:46 PM
Topic tags/keywords: question drill-driver cordless batteries
Recently I have been wondering, is it a problem to leave your cordless tool batteries on the charger even after they are finished charging? I have Porter Cable drill set, and there are times where I forget to remove them after they are finished charging. Is this a problem? Will it limit the life of the batteries? Thanks!
-- Dale Miller Modesto, CA "I can do all things through Christ, which strengtheneth me." Philippians 4:13. "Woodworking minus patience equals firewood."
25 replies so far
View Loren's profile
10476 posts in 3673 days
#1 posted 08-08-2017 06:52 PM
I doubt there’s harm in it with lithium
batteries. Modern chargers have circuitry
in them to prevent over-charging.
One of the worst things you can do it
put a hot battery straight from a tool
you’ve been using onto the charger.
That really cooks them.
View Ripper70's profile (online now)
Ripper70
1023 posts in 934 days
#2 posted 08-08-2017 07:11 PM
It may depend on the charger/battery combo you’re using. Some of the PC chargers have overcharge protection to prevent the kind of damage that you’re concerned about. Check your models number and do a Google search to get the specifics.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View MrUnix's profile
MrUnix
6766 posts in 2224 days
#3 posted 08-08-2017 07:31 PM
Yup. Depends on the charger. One of my Makita chargers has a “T” at the end of the model #, indicating that its got a trickle charge function so you can leave them in after a full charge. The manual for my other one recommends removing the battery after charging. It’s all up to the charger and how smart it is.
View splintergroup's profile
splintergroup
2075 posts in 1247 days
#4 posted 08-08-2017 07:50 PM
I place my chargers on an old mechanical type light timer set to only run for 1 hour per day. This keeps the batteries topped up, but prevents any possibility of long-term overcharging. It also saves a small amount of power based on testing.
View Karda's profile
Karda
1113 posts in 579 days
#5 posted 08-08-2017 07:54 PM
I have an 18v drill from HF, the battery takes 3-5 hours to charge, manual says charging for more than 7 hours will damage the battery
View Redoak49's profile
Redoak49
3283 posts in 2014 days
#6 posted 08-08-2017 08:02 PM
I wired up an outlet with an electronic bathroom fan timer and set it for 60 minutes which charges any of my lithium batteries.
View Gilley23's profile
Gilley23
489 posts in 407 days
#7 posted 08-08-2017 08:02 PM
Just using that HF battery will damage the battery.
4999 posts in 2518 days
#8 posted 08-08-2017 08:06 PM
The newer (quality) chargers have solved the problems associated with leaving them in there. I still use a setup from the NiCad days where I have all my chargers plugged into a power strip and the strip is plugged into a 7 day electronic timer. It turns on for 2 hours (I think, can’t remember) once each week so I didn’t worry about the overcharging. I could probably ditch that now, but it’s not doing any harm.
View hotbyte's profile
hotbyte
991 posts in 3001 days
#9 posted 08-08-2017 08:09 PM
I’ve always put them directly on charger from tool…thanks for info on that not being good for them! I’ll have to develop habit of leaving them off for a spell and then putting on charger. Knowing me, I’ll remember a few days later when I need them again :(
Kind of unrelated, but we’ve bought a 40V blower and push mower (yes, mower) from Ryobi and they actually work pretty good. They have a chain saw that runs on 2 40V batteries.
I doubt there s harm in it with lithium
you ve been using onto the charger.
- Loren
#10 posted 08-08-2017 08:14 PM
I ve always put them directly on charger from tool…thanks for info on that not being good for them! I ll have to develop habit of leaving them off for a spell and then putting on charger. Knowing me, I ll remember a few days later when I need them again :(
Kind of unrelated, but we ve bought a 40V blower and push mower (yes, mower) from Ryobi and they actually work pretty good. They have a chain saw that runs on 2 40V batteries.
It’s the worst with the batteries in the larger
packs because the cells on the outside of
the cluster insulate the hot cells on the
inside. That’s why those Makita packs from
the drills with the long handles lasted so
long – it was just a stack of paired cells
so they dissipated heat well.
View plasma800's profile
plasma800
10 posts in 384 days
#11 posted 08-08-2017 08:17 PM
I didn’t read every post, maybe somebody already said this..
but I NEVER leave batteries on the chargers.
I had one melt over night into a steaming too hot to touch puddle of smoldering plastic and battery bits.. ever since then, I monitor all battery charging when I’m in the shop. If I leave the shop for any considerable time, I have one power strip that I flip off that pulls power from all chargers, and the LED lights on my miter saw station… it’s my shut down switch.
DMiller
#12 posted 08-08-2017 08:18 PM
Thanks for the replies, guys! I really appreciate your answers!
View TaySC's profile
TaySC
270 posts in 358 days
#13 posted 08-08-2017 08:58 PM
It’s been maybe 10 years ago, but I ruined a Dremel battery by leaving it on the chrger around the clock. Thankfully, technology has improved and trickle chRogers should prevent that from happening.
View Jack Lewis's profile
Jack Lewis
276 posts in 1103 days
#14 posted 08-08-2017 09:03 PM
I wonder how flashlight companies would feel if every company had a different shaped batttery? E.I. automobile manufactures. Same bitch about ink jet printers.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
View JackDuren's profile
JackDuren
388 posts in 985 days
#15 posted 08-08-2017 09:41 PM
Leaving on trickle killed four of my dewalts…$70 ea
