How do you number table leaves?
Forum topic by TungOil posted 08-08-2017 06:32 PM 547 views 0 times favorited 12 replies Add to Favorites Watch
View TungOil's profile
TungOil
1080 posts in 731 days
08-08-2017 06:32 PM
I’m finishing up a dining table build with four leaves. The veneer on the leaves is slip matched so there is a specific order that they can go in to look best, so I want to number the leaves. How have you numbered leaves to keep them in order?
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
12 replies so far
View BenDupre's profile
BenDupre
689 posts in 724 days
#1 posted 08-08-2017 07:40 PM
Make a V across all the leaves
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
View Rich's profile
Rich
3996 posts in 826 days
#2 posted 08-09-2017 01:03 AM
I assume this is to ensure they go in correct order each time the table is set up for use. I don’t know what sort of alignment you’re using, but if it’s, say, pins and matching holes, you could vary the spacing so that the leaves will only attach to one another in a particular order.
View Nubsnstubs's profile
Nubsnstubs
1434 posts in 1966 days
#3 posted 08-09-2017 01:25 AM
If you are trying to have all the wood match when all the leaves are in, use 1,2,3,4 and four, with an arrow pointing to either 0 or five, and keep that in mind for the future. BUT, once the leaves are pulled out and stored, there goes your order you built into your table. Win Win , Lose Lose. Take your pick…........... Jerry (in Tucson)
TungOil
#4 posted 08-09-2017 02:11 AM
I assume this is to ensure they go in correct order each time the table is set up for use. I don t know what sort of alignment you re using, but if it s, say, pins and matching holes, you could vary the spacing so that the leaves will only attach to one another in a particular order.
- RichTaylor
Yes, I should have been more clear, this is to number them after the table is finished so the leaves will go in the correct order to keep the grain match.
Offsetting the pins would have been a good idea…...if I had asked this question before last weekend when I installed all the alignment pins.
I’m thinking there must be a slick way to number them. Maybe a small laser engraver…..
View 000's profile
000
2859 posts in 1135 days
#5 posted 08-09-2017 02:13 AM
Inset brass dowels into the edges.
TungOil
#6 posted 08-09-2017 02:16 AM
- jbay
jay- can you elaborate on that a little please?
View Loren's profile
10477 posts in 3884 days
#7 posted 08-09-2017 02:21 AM
You could stamp numbers on the edges. With
4 leaves you would have 5 joints, so each half
of joint no. 1 would be stamped with a “1”
or an “a”.
Harbor Freight sells stamp sets and they can
also be had from ebay.
View Rich's profile
Rich
#8 posted 08-09-2017 02:22 AM
- TungOil
You could still add one extra pin per leaf with each one progressively located.
Edit: Or you could take a Sharpie and number them underneath. That’s probably what I’d do, but I have no class.
Edit Edit: OK, here you go. Mark each intersection with the astrological sign of members of your family. Have the sign cross the joint, so it’ll be easy to see how they align.
That wouldn’t work for me though, because I’m a Libra, and Libra’s don’t believe in astrology.
View AZWoody's profile
AZWoody
1419 posts in 1460 days
#9 posted 08-09-2017 02:24 AM
Can you place a dowel as an alignment pin, or some sort of metal pin that is in a different spot on each leaf so that it can only be inserted on that one side?
It’s along the same lines as having your dowels in a different spot for each one, but this is just one that would have to drill for each one.
And I should have read the other comments more closely. It’s what Jbay was also saying. You basically add one more dowel/brass pin to each leaf, in different areas.
View 000's profile
000
#10 posted 08-09-2017 02:37 AM
Drill holes in edges insert dowels, sand flush, finish.
1 dowel in table edge – 1 dowel in first leaf
2 dowels opposite side of first leaf – 2 dowels in second leaf
3 dowels opposite side so on and so on
#11 posted 08-09-2017 02:42 AM
- jbay
That’s a good idea.
I used bristles from a plastic hairbrush once
to make marker inlays for the edge of a guitar
fingerboard.
TungOil
#12 posted 08-09-2017 03:27 AM
- jbay
ahhhhh, good idea. This would work well since I need to build a box to hold all these leaves and they will likely be edge up in storage. this would make it easy to see which one is next. but you guys are supposed to be talking me into one of those little laser engraver thingies….
