Spray lacquer finishing
Forum topic by Steve22629CALVI posted 08-08-2017 06:04 PM 386 views 0 times favorited 2 replies Add to Favorites Watch
View Steve22629CALVI's profile
1 post in 225 days
08-08-2017 06:04 PM
I built a African Mahagony table top. Sanded with 220grit. I have never used lacquer before, but wanted to try it due to how quick it dries and re coat. Sprayed 2 coats the lightly sanded with 400 grit and applied 3rd coat.the top looked good and was very smoo am trying to achieve a “glass Top” type result, so I used a #4 pumice slurry and rubbed over top and hand buffed off. Top was looking good so was going to add a few more coats of lacquer and repeat the process. Before I sprayed I wiped the top down with mineral spirits it ruined the top. Had all kinds of white splotches all over top. What di
2 replies so far
View TungOil's profile (online now)
869 posts in 428 days
#1 posted 08-08-2017 06:29 PM
you must have resoftened the finish with the mineral spirits. lacquer coats melt into each other (the top coat softens the previous coat and they become one film). I think your best bet will be to sand out the mess and respray. Hopefully Charles will chime in, he is the expert.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Rich's profile
2472 posts in 523 days
#2 posted 08-09-2017 01:30 AM
I’ve never had mineral spirits or naphtha soften a lacquer finish. What did you use with the pumice? I use paraffin oil, and find it works best.
Now, here’s my take on what you’re doing. You don’t use pumice between coats of lacquer. In fact, you shouldn’t need to do any sanding at all, and if you do, maybe 600 grit. Like Tung said, lacquer blends into earlier coats, so you don’t need any roughing like with some other topcoats.
If you’re really going for that piano finish, you’ll need to fill the African mahogany grain first. I use it a lot and it’s very porous. It’ll take forever to fill that with lacquer. Also, do all of your coats of lacquer before you try any rub out with pumice — it’s a final step. And finally, pumice 4F is still pretty gritty, so get some rottenstone to use after the pumice. At the end of it all, you can use mineral spirits or naphtha to clean up, but don’t do it between coats of lacquer.
And, above all, practice on test boards. Figure all of this out before you even think about touching your actual table top. It will save you a world of misery. Just take some pieces of the wood, sand them exactly as you will your table top and try different recipes. Take notes too.
-- No matter how much you push the envelope, it'll still be stationery.
