Dust collection fiber barrels
Forum topic by JamesG2222 posted 08-08-2017 05:46 PM 625 views 0 times favorited 4 replies Add to Favorites Watch
View JamesG2222's profile
JamesG2222
2 posts in 1390 days
08-08-2017 05:46 PM
Topic tags/keywords: fiber barrel thein baffle
I hope this is an OK spot to post this first post. I am trying to add a thein baffle and I want to use a fiber barrel with an entrance on the side so that the dust comes in at the highest possible speed. Locally I can find free 55 gallon fiber drums. This would be a little too tall for the plan I have in mind has anyone ever cut a fiber barrel down to size if so what happens when you cut it can you keep a straight edge?
Thanks, Jim
View johnstoneb's profile
johnstoneb
2788 posts in 2078 days
#1 posted 08-08-2017 05:56 PM
The more height the better. You need it for capacity.
-- Bruce, Boise, ID
View Fred Hargis's profile (online now)
4875 posts in 2398 days
#2 posted 08-08-2017 08:13 PM
I’ve never cut a fiber barrel but have done a few wooden ones as well as metal ones…...I’ve never been able to cut it straight. But I don’t think that’s the only problem, you need to get the metal ring put back onto to for stiffness. Still, if the 55 gallon drums are free, it doesn’t cost anything to try.
View tomsteve's profile
tomsteve
753 posts in 1124 days
#3 posted 08-08-2017 09:36 PM
keeping a straight edge is simple.
ive cut plastic, fiber, and metal drums by using my circ saw and using the floor as my guide.metal cutting blade for the metal drum. cuts about 1 1/2” up.
made a gage once when i was stacking 2 plastic drums for my DC- a piece of wood cut to length where i wanted the cut, taped a marker on one end and nailed a little leg on the other that rode on top of the drum. ran it around the drum to mark where i wanted the cut then used my circ saw with a plywood blade.worked like a charm both ways.
fiber drums got a little flimsy, so i just took a piece of the cutoff and glued it around the top- instant garbage can.
JamesG2222
#4 posted 08-09-2017 02:24 AM
Thanks,
This is a great site to get help
