Help me improve this shop space
Forum topic by newbiewoodworker posted 01-10-2011 03:34 AM 1849 views 2 times favorited 32 replies Add to Favorites Watch
View newbiewoodworker's profile
newbiewoodworker
668 posts in 2821 days
01-10-2011 03:34 AM
Frankly, I am always tripping over stuff… Also, it is a bugger work for long periods in.
But, maybe you can provice me with some ideas on how to make the shop a little more cozzy…
Don’t get me wrong.. I love my little shop… its where I go to stress relieve… but when you trip and go falling into the workbench.. it is never fun….
Here are the pics, for you to provide suggestions from.
-- "Ah, So your not really a newbie, but a I betterbie."
32 replies so far
View richgreer's profile
richgreer
4541 posts in 3068 days
#1 posted 01-10-2011 03:48 AM
It’s pretty hard to tell you what to do based on these pictures, but I will make 2 points that may be helpful.
- I see a lot of available wall space where you could put up shelves and/or pegboard or what ever and get more stuff off the floor.
- Get the wood you are not currently using out of the shop. Of course, that assumes you have someplace out of the shop to store the wood.
newbiewoodworker
#2 posted 01-10-2011 03:58 AM
Frankly, I do a mess of different things… I think I am going to stop with the big stuff after this, and start making a few end grain cutting boards… after I squeeze a TS in there…lol..
Things like the planer are on wheels.
Also, I think, that bench is going to get turned. and put on a wall, rather than in the center of the room, jutting out 8ft into the 24ft space.
Oh yea, the Garage is 24×13ft
View quartrsawn's profile
quartrsawn
146 posts in 3207 days
#3 posted 01-10-2011 04:00 AM
First I would get the ladder off the floor,hang it on wall or from ceiling, those plastic covered screw in metal hooks work well.The wall over the trash cans looks like a good spot. Then get rid of the trash and mt boxes and turn your work bench and shelf unit parallel to the rear wall.Then place your air compressor under your bench. A lumber rack on wall over miter saw is also something to consider . Hope this helps.
-- Nat - West Sayville,L.I., NY
View PurpLev's profile
PurpLev
8535 posts in 3642 days
#4 posted 01-10-2011 04:03 AM
looks like you have quite a bit of space there – not as small as you think it is. the idea though is to make it efficient.
for smaller shop space like yours it is best to keep everything on wheels/mobile bases, and store everything on the perimeter including workbenches and what not, and use the center for movement and to get to everything. Once you place anything in the center area you are blocking your entire work access – I had the same thing with my TS somewhat in the center which was practically impossible to do anything without getting bruised. I recently rearranged everything to be on the perimeter and for most operations I don’t need to move anything, although for some operations I’ll pull the bandsaw, or router to the center to do something – then put it back in place.
http://lumberjocks.com/PurpLev/blog/17604
View Joe Lyddon's profile
Joe Lyddon
10091 posts in 4046 days
#5 posted 01-10-2011 04:07 AM
Golly, I wish my shop was as clean as yours! :) :)
newbiewoodworker
#6 posted 01-10-2011 04:10 AM
Good ideas.
I like to be able to work from 2 sides of the bench, because if I am working on something substancial, then I dont have to spin a 40lb coffee table, like a break dancer.. lol…
The trash must stay…. trust me, I have tried to get it out of there… but pops wants it inside…
The ladder I do actually use occasionally… but yea, it needs to go..
Same with the snowblower… but my father wants that to stay too…grr…
I do agree.. its not at all efficient…
I do have a lumber rack, I didnt picture it.. → In pic 1 do you see the light closest to the camera. Well thats a hump. On the other side of that hump, is a set of hooks, that I lay my lumber across.. Its up out of the way… although occasionally hairy to get stuff off of…
View Eric_S's profile
Eric_S
1565 posts in 3189 days
#7 posted 01-10-2011 04:11 AM
I see a lot of unused wall space. That would be the first thing I’d think about. In a small area, the more stuff off the ground and out of the way the better IMO. Also, I used to keep my trash cans in the garage too and realized how much space they take up. If your neighbors dont mind and you dont have animals near by, see if you can put them on the side of your house.
-- - Eric Noblesville, IN
newbiewoodworker
#8 posted 01-10-2011 04:11 AM
Its not at all clean… I just picked up the week old Nitrile gloves off the floor today..!
There is sawdust all over… it needs a cleaning.. lol…
View Arthur C. Peterson's profile
Arthur C. Peterson
23 posts in 3752 days
#9 posted 01-10-2011 05:39 AM
I have about the same size shop as you. i too am new to wood working but having a lot of fun. If you go to my home and look at my shop I just put pictures there so you could see. Everything I have is on wheels but it works. Good luck. Art Wasilla, Alaska
13603 posts in 3335 days
#10 posted 01-10-2011 05:54 AM
more cabs
more racks
french cleats
move things around
till they find their place
(they always do
for maximum usage)
or you could do this
and just work around it
till you are in a corner lol
newbiewoodworker
#11 posted 01-10-2011 05:58 AM
looks good… lol…jk
View Sarit's profile
Sarit
549 posts in 3133 days
#12 posted 01-10-2011 06:42 AM
I know this sounds crazy, but maybe you can build an interior wall in the back to serve as a nook to store the trashcans, wood, ladders, snow equipment. It would be parallel to the back wall (about 5-8 feet away from it), but not as wide so that you can get back there. Once you put a bunch of shelves in there, you won’t believe how much you can store there. Then the rest of your shop can be dedicated to woodworking.
Rather than one big bench, you could have a few smaller benches of the same height on wheels and leveling feet that you could reconfigure as needed and store against the wall when not. When you need a big bench, just put them next to each other and add some clamps.
18615 posts in 4154 days
#13 posted 01-10-2011 12:22 PM
look up – space in/near the ceiling
look forward – wall space for cabinets, shelves, hanging stuff
look down – spaces under benches, shelves? space for equipment on wheels?
organize – put rarely used stuff in bins that can be stacked etc… just making it “invisible” will help make the space feel better.
View hairy's profile
hairy
2701 posts in 3526 days
#14 posted 01-10-2011 06:56 PM
Have you tried the shop planner at grizzly?
http://www.grizzly.com/workshopplanner.aspx
-- My reality check bounced...
View 8iowa's profile
8iowa
1580 posts in 3755 days
#15 posted 01-10-2011 07:43 PM
It appears that the only natuiral light comes from the windows on the garage door. Install several 4’ T-8 fixtures on the ceiling. Paint walls and ceiling white to further brighten up the space. You will be amazed at how much this helps.
If possible, install additional electrical recepticles on the wall, about 42” high. This will reduce having to step on cords on the floor, and possible eliminate the need for extension cords.
As Rich advised, I too recommend shelving on the walls. Shelving is much more versatile than cabinets. I also find that the metal “mechanic’s” tool cabinets with drawers, ie: Craftsman, are much more space efficient in the very small shop than pegboard. I keep my tool cabinets in front of the garage door. Since they are on casters, they can be moved if the door needs to be opened for access.
showing 1 through 15 of 32 replies
