Cross legs for picnic table
Forum topic by dfox52 posted 08-08-2017 03:18 PM 393 views 0 times favorited 5 replies Add to Favorites Watch
View dfox52's profile
dfox52
27 posts in 1722 days
08-08-2017 03:18 PM
What is the best way to layout the diagonal half lap cuts for “X” shaped picnic table legs? I’ve cut my pieces to length using a rectangular template but am having dificulty accurately laying out the diagonal lap joint cuts. I’ve tried clamping the two pieces together and adjusting but that is awkward and seems like there should be a more accurate method. Any suggestions? I don’t mind doing some math if that is what it takes… :)
Thanks!
5 replies so far
View Woodknack's profile (online now)
Woodknack
11825 posts in 2408 days
#1 posted 08-08-2017 04:38 PM
The math is more complicated than expected but I think someone posted it the last time this was asked. Far quicker to either draw it full size or clamp and mark the pieces.
View bondogaposis's profile
bondogaposis
4770 posts in 2379 days
#2 posted 08-08-2017 04:54 PM
Make a full size drawing then use that to set your bevel gauge.
-- Bondo Gaposis
View hotbyte's profile
hotbyte
991 posts in 3004 days
#3 posted 08-08-2017 05:01 PM
Lay them on flat ground or driveway and support the top piece of X with scraps under the end so it doesn’t wobble like a weeble and fall down. Align/measure everything and mark.
dfox52
#4 posted 08-08-2017 06:04 PM
Maybe I’m just too picky but it seems almost impossible to get both “Xs” precisely the same. A tiny variance in the lap joint magnifies into a 1/4 to 1/2 inch difference in the height of the X. I was just wondering if there might be a jig that would ensure all four pieces are identical.
View gargey's profile
gargey
997 posts in 804 days
#5 posted 08-08-2017 06:35 PM
lasers
