Finishing question
Forum topic by unclearthur posted 08-08-2017 07:17 AM 528 views 0 times favorited 6 replies Add to Favorites Watch
View unclearthur's profile
unclearthur
180 posts in 1816 days
08-08-2017 07:17 AM
A general question about applying a varnish finish by brush to both sides of a project For example, I’m going to brush on polyurethane to finish both sides of a footboard for a bed. I want both sides to look good.
I’m curious which is the best approach,
i) Brush on one side, flip it resting on “painters pyramids” or similiar, do the other side, and try to fix the marks later – in my experience the hidden bottom side always comes out looking rough (droplets, etc).
ii) Hold or hang it vertically and do both sides at same time – negative is having to worry about runs on the vertical surfaces ….. ie – easier to finish horizontal surfaces
iii) do one side, let dry, flip, do other side. But this takes 2 x as long and maybe have a line where the two sides meet?
Thanks for your thoughts …..
5002 posts in 2522 days
#1 posted 08-08-2017 02:04 PM
I’ve never had any luck using the painters pyramids with varnish. It’s not the fastest, but I would let one side set up, and then flip it. The other way i do may not work for you, but I’ll put screws or nails into unseen spots and use them to support the piece, that allows me to rotate it before the top side has dried. If you elect to go the pyramid route, I’d suggest you make your own using very fine nails for the resting points.
View bbasiaga's profile
bbasiaga
1234 posts in 2024 days
#2 posted 08-08-2017 02:38 PM
You can also spray it while it is standing up, if you have the equipment. Go light and it will not run.
Otherwise, you’ve got to do the flip method. I have started using faster drying finishes in conjunction with spraying to cut down finishing time. You could go with a shellac base coat to get some color, then a water based topcoat. Shellac dries in 15min. The water based topcoat are hard and durable and dry in an hour or two depending on humidity.
Brian
View bobkberg's profile
bobkberg
439 posts in 3102 days
#3 posted 08-11-2017 05:20 AM
Lately, I’ve been using the wipe-on poly, and have zero drip/run problems. The downside is that to get a decent gloss takes more coats. If I want a really high gloss, then I use a sprayer and a light coat.
For both sides, I make hooks out of coat hangers and staple the hook to the underside (or other non-critical surface).
Good luck,
-- Bob www.singularengineering.com - A sideline, not how I earn a living
View TungOil's profile
TungOil
945 posts in 524 days
#4 posted 08-11-2017 07:36 PM
Same here, I gave up trying to brush poly. I either wipe small items or spray.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Manitario's profile
Manitario
2630 posts in 2912 days
#5 posted 08-11-2017 08:10 PM
I agree with what others have said, every time I brush varnish I say “never again”. Wipe on might need more coats but is far simpler to get a good result.
View buckbuster31's profile
buckbuster31
248 posts in 544 days
#6 posted 08-11-2017 09:04 PM
wipe on only for me
