Dovetail joinery for hexagon joints?
Forum topic by ChrisCarr posted 01-09-2011 09:57 PM 3637 views 0 times favorited 1 reply Add to Favorites Watch
View ChrisCarr's profile
ChrisCarr
196 posts in 2807 days
01-09-2011 09:57 PM
I am going to build one of those table saw dovetail cutting jigs. However I need to know if it is possible to cut dovetails normally on them though the boards ends will be beveled 45 degrees because the project is hexagon shaped.
The jig i am building is from a fellow LJ’s…
http://lumberjocks.com/projects/22450
1 reply so far
TopamaxSurvivor
18199 posts in 3585 days
#1 posted 01-10-2011 10:39 AM
That jig will not make the proper cuts for them. You could use a dovetail joint, but it will have to open up to 120 degree corner from a 90 degree corner so they will not be cut straight through the board. The bottom of the dovetail and pins would be on a 30 degree angle to the surface of the boards froming the hexagon.
