Stitching Scanned Articles into a PDF
Forum topic by Hoakie posted 01-09-2011 08:56 PM 1148 views 5 times favorited 10 replies Add to Favorites Watch
View Hoakie's profile
Hoakie
306 posts in 3938 days
01-09-2011 08:56 PM
I recently obtained a lot of old WW mags from a friend that he was getting rid of. Since I didn’t want to keep them myself, I scanned only the articles of interest. I kept them in separate directories by the title of the article but didn’t rename them from image1.jpg, image2.jpg, etc. The problem I ran into is that each time i want to look at the article I have to open all the pages as separate images. This was especially cumbersome since i didn’t give each one a unique name.
Being a software developer, I decided to write a little utility that will go through a directory and pull its contents into a PDF file so all of the pictures are contained in one file.
If you are interested in trying it out feel free. You can get a copy of the application here.
To use:
  1. Unzip the files to a directory of your choice and run the executable.
  2. Select a source directory where your images reside.
  3. Select an output directory where to put the PDFs.
  4. Press the Create button.
This application needs Microsoft’s .NET Framework 4.0 to run, so if you run into problems, you may need to install it as well. It can be found here
A few other notes:
  • The PDF file will contain all the images in the directory or sub directory
  • The application should ignore all files in the directories that it does not recognize as an image file
  • The PDF file will be named the directory name and any spaces get converted to underscores.
Please let me know if you find this useful or have any questions.
Thanks for looking
-- John H. [To invent, you need a good imagination and a pile of junk. ~Edison]
10 replies so far
View Peter Oxley's profile
Peter Oxley
1426 posts in 3777 days
#1 posted 01-09-2011 09:16 PM
This looks really useful – I’m going to give it a try. Thanks for sharing!
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
Hoakie
#2 posted 01-10-2011 12:32 AM
Your welcome
Let me know how it works for you. I also like to use it to package pictures of the kids up for the parents so they only need to have one file
View lew's profile
lew
11939 posts in 3658 days
#3 posted 01-10-2011 01:17 AM
Thanks, John!
This works great!
Lew
View KayBee's profile
KayBee
1083 posts in 3149 days
#4 posted 01-10-2011 02:52 AM
Looks great, but I use a mac : (
-- Karen - a little bit of stupid goes a long way
Hoakie
#5 posted 01-10-2011 04:01 AM
Yeah thats a problem…I guess you could install and Run windows using BootCamp
View FredG's profile
FredG
139 posts in 3599 days
#6 posted 01-10-2011 06:20 AM
On Linux (Ubuntu) a program called imagemagick is already installed.
It’s a command line tool. Just enter <name>.jpg <name>.pdf
For Mac users this might be interesting.
http://www.imagemagick.org/script/binary-releases.php
Everybody happy !!
-- Fred
Hoakie
#7 posted 01-10-2011 06:42 AM
Fred,
That looks like a cool utility and I can probably us it in the future. Thanks for sharing
However, what my program does is to condense all the images in a directory structure into one PDF file. For instance if I scan a four page article (4 image files) into a directory, it will create one PDF file with 4 pages. It also lets you recursively walk through a set of directories and sub directories and create multiple PDF documents (one per directory). This is useful if you spend have a bunch of articles already scanned. With Image Magick, it looks like it only does a 1:1 file conversion so it is a bit different. I didn’t look too closely but maybe you can stitch multiple image files together with it.
FredG
#8 posted 01-10-2011 07:04 AM
Hi John,
In Ubuntu I just type: convert <name1>.jpg <name>.pdf <name2>.jpg <name>.pdf
So the same name for the pdf.
-- Fred
Hoakie
#9 posted 01-10-2011 07:13 AM
So does that appends each image to the PDF then? That’s pretty slick.
However it would still require a lot of typing for what I created my app for. I needed to convert 64 directories which had and average of about 4-6 images/directory. It only takes about 40 seconds to process the images and the 64 PDFs.
I assume you could couple this with a scripting language to recurse through a directory structure to accomplish something similar to what I created. I’ll have to poke around some more…but I tend to live in the .NET world ;)
FredG
#10 posted 01-10-2011 07:27 AM
Never had so many images. There are other options in the program.
One is montage. But I don’t know if you can paste and copy into the command line.
I’ll check that tomorrow (Well this afternoon, it’s 6:30 AM, haven’t seen my bed yet.
-- Fred
