Ever have one?
Forum topic by Aj2 posted 08-07-2017 03:30 AM 698 views 0 times favorited 8 replies Add to Favorites Watch
View Aj2's profile
1304 posts in 1729 days
08-07-2017 03:30 AM
I might go get this little gem.
What do you guys think
-- Aj
8 replies so far
View Loren's profile
10081 posts in 3578 days
#1 posted 08-07-2017 03:58 AM
That’s pretty old to be in new condition…
probably from the 70s or 80s. If a 4”
jointer can serve your needs it will
probably be fine and money well spent.
I had a 4” jointer when I was starting out.
Knowing what I know now about flattening
boards and shooting edges with hand
planes, I probably could have got by
for a lot longer with that jointer, but as
it was, I soon upgraded to a series of
larger jointers.
View doubleDD's profile
7216 posts in 1974 days
#2 posted 08-07-2017 04:32 AM
For $50 bucks, new, I can’t see going wrong. Back in the early 70’s I had a similar craftsman and worked out fine for me till I outgrew it. Should be a great starter.
View Woodknack's profile
11293 posts in 2311 days
#3 posted 08-07-2017 07:09 AM
I would be all over it. Cheapest one one I’ve seen locally was $75 without a motor. I kept offering $50 and he refused.
-- Rick M,
View Clarkie's profile
453 posts in 1772 days
#4 posted 08-07-2017 11:54 AM
Hello Aj2, I would pass on the lil craftsman, you’ll find it to be just a rest stop and frustrating. Hold off till you find a good old 6” jointer, hopefully a Delta. The knives in the craftsman will not hold up. So, keep in mind, a big jointer will do small jobs as well as larger jobs, but the small machine will only do small jobs. Have fun, make some dust.
View mahdee's profile
3850 posts in 1698 days
#5 posted 08-07-2017 01:35 PM
I would check availability of the blades and belt first.
View Planeman40's profile
1120 posts in 2692 days
#6 posted 08-07-2017 01:51 PM
This should work fine for most of your needs in a home shop. I have a 6” jointer and rarely need the full 6” to do edges. Some people use a jointer to plane a board to make it thinner or to clean up a side and this really needs a larger jointer. But for this you would be much better off buying a 12” thickness planer. Blades should be available. Look online.
View Aj2's profile
#7 posted 08-07-2017 01:54 PM
I probably will pass I think it’s has a fixed out feed table.
I’ve had lots of different jointers been looking for something real small for my small box I make.
Thanks guys
-- Aj
View Holt's profile
227 posts in 2560 days
#8 posted 08-07-2017 03:49 PM
I have a similar attachment for my Shopsmith. Not the worlds best jointer, but handy for small projects. Don’t think I’d want this as my only jointer, the width might be fine for most projects, but the short beds could be problematic for longer pieces.
-- ...Specialization is for insects.
