Shortening Chain on Veritas Twin-screw Vise Help
Forum topic by groland posted 01-08-2011 11:08 PM 1042 views 0 times favorited 3 replies Add to Favorites Watch
View groland's profile
groland
181 posts in 3288 days
01-08-2011 11:08 PM
I have to shorten the chain on my Veritas Twin-Screw Vise as per the instructions on p. 3 of the instruction booklet. I have filed off the peened heads of two link pins as indicated in the illustration, but the links won’t separate. I do not want to damage the chain. How does the chain separate or how do I get it apart? Do I need to file off the end on the link pins on the opposite side? That doesn’t seem to be indicated in the instructions.
Any help much appreciated.
George
3 replies so far
View Dennisgrosen's profile
Dennisgrosen
10876 posts in 2991 days
#1 posted 01-08-2011 11:27 PM
yes of to a bicycleshop and get the tool
and if you get the right one it can allso help you connecting them again
there is two different types of chains those on racercycle´s and motorcycle´s
and then there is those that is connected and locked with an outside splittype (older bicycle´s )
good luck with it :-)
Dennis
groland
#2 posted 01-09-2011 03:28 AM
Thanks very much for everyone’s help! I have no patience to wait until Monday for the bicycle shop, so I drilled a hole in a block of wood, got a hammer and a little punch and drove out the pins as was suggested by Cessna Pilot Barry. Worked like a charm and the vise is working now.
Thanks for your replies!
George
View WoodLe's profile
WoodLe
155 posts in 2672 days
#3 posted 01-09-2011 04:02 AM
I usually grind off the end of the pin and they pop right out.
-- www.largewoodslabs.com Wooster, Ohio
