Grizzly Table Saw Blade Spin Down*Updated 8/11/17*
Forum topic by seturner posted 08-06-2017 03:59 PM 1078 views 0 times favorited 32 replies Add to Favorites Watch
View seturner's profile
seturner
29 posts in 447 days
08-06-2017 03:59 PM
Hello,
I recently purchased a used Grizzly 1023RLW with 3hp motor. It replaced a nice Delta contractors saw with 1-1/2hp motor. I noticed that my Grizzly has a very long spin down for the blade after powering down, I would say twice as long as the Delta.
Is a long spin down normal on this type of saw? Is there supposed to be a brake of sorts? I would estimate it takes 15 seconds to stop spinning after turning off.
Thanks
Edit: Added video. Startup squeal, power off at 10 seconds, blade stop at 37 seconds. This is after I tightened belt, which took time to stop from 31 seconds to 27 seconds.
UPDATE 8/8/17
I pulled the arbor and bearings today. The bearing furthest from blade was essentially frozen, and the other one was gritty. I bought some new SKF bearings and installed, but I damaged the threads on the arbor like an idiot by hammering on the arbor shaft directly. I think it will be cheaper to buy a new arbor than buying dies, since one end(away from blade) is reverse threaded fine pitch, and the blade side is right hand threaded coarse pitch.
Thanks for your help, and I believe Mr. Unix had it right all along.
UPDATE 8/11/17
Got the new arbor today and installed with the new bearings. The blade now stops in 12 seconds!
https://youtu.be/cz85ptoWIL0
View on YouTube
32 replies so far
View MrUnix's profile
MrUnix
6768 posts in 2226 days
#1 posted 08-06-2017 04:21 PM
No brake… but an unusually long spin down time can indicate bad bearings. Typical spin down time with a standard blade should be about 5-7 seconds give or take a few. You might also want to take a look at the belt tension.
seturner
#2 posted 08-06-2017 04:31 PM
I just went out and timed it with watch. From the time I press Stop button to blade motionless is 31 seconds, which is worse than I said.
The saw seems to run smoothly, their is a short squeal when I first start it, like a belt noise.
View Andre's profile
Andre
1888 posts in 1834 days
#3 posted 08-06-2017 04:40 PM
I would think good bearings and perhaps belt just a little loose causing slippage on startup?
Think about bandsaws, large cast wheels take forever to stop turning hence the addition of foot brakes!
View Rich's profile (online now)
Rich
3015 posts in 617 days
#4 posted 08-06-2017 04:41 PM
- MrUnix
Not arguing with you, but how would bad bearings increase the time to spin down?
MrUnix
#5 posted 08-06-2017 05:22 PM
- RichTaylor
Good bearings, with proper grease, have some resistance to spinning… if you take one and hold it by it’s inner race and spin it, it will free spin maybe once or twice but no more. Once the grease goes away (or turns to wax), you can do the same and it will free spin a lot. If you have a used machine, there is no telling when (or if) those bearings have ever been changed. They do not last forever.
I don’t know how many times I’ve heard people say “I spin them and they spin forever, so they must be good!”. Doh!
Rich
#6 posted 08-06-2017 05:30 PM
- MrUnix
OK, thanks. That makes sense now that you explain it.
View unbob's profile
unbob
810 posts in 1931 days
#7 posted 08-06-2017 06:53 PM
I have a Delta with the 1 1/2hp motor, it has an effective internal brake, the saw shudders a little when the switch is turned to off.
Other motors like the 1 1/2hp motor in my Griz jointer. takes longer to spin down. The brake is a safety feature
Dry bearings are most noticeable in radial saws, can take a long time to spin down.
MrUnix
#8 posted 08-06-2017 07:01 PM
- unbob
I don’t believe I have ever seen a Delta TS that had a brake… What model saw, and is it an aftermarket braking system? Or are you talking about the centrifugal switch closing down (which many people confuse with a brake as it does slow the motor down a bit when engaged)?
View JackDuren's profile
JackDuren
388 posts in 987 days
#9 posted 08-06-2017 07:14 PM
Call Grizzly…
View Woodknack's profile
Woodknack
11818 posts in 2408 days
#10 posted 08-06-2017 07:22 PM
30 seconds does seem like a long time. I would check belt tension. Lot of people own Grizzly, might add “Grizzly” to the title and get more responses.
unbob
#11 posted 08-07-2017 12:33 AM
<blockquo>
- unbob
I don t believe I have ever seen a Delta TS that had a brake… What model saw, and is it an aftermarket braking system? Or are you talking about the centrifugal switch closing down (which many people confuse with a brake as it does slow the motor down a bit when engaged)?
- MrUnix
The saw is a 1979 Rockwell 10” contractors saw, with the original Rockwell 1 1/2hp motor. I have read others thinking something is wrong with their motor, when the switch is flipped off the, saw shudders from the braking action as it slows down.
MrUnix
#12 posted 08-07-2017 12:39 AM
- unbob
That is pretty typical on a single phase induction motor – as the centrifugal switch closes and the start windings/capacitor are brought back into circuit (combined with the friction induced from the centrifugal switch itself)... and it’s exaggerated on machines with the motor hanging out the back. It’s not a brake, but many confuse it as such :)
View TungOil's profile
TungOil
945 posts in 523 days
#13 posted 08-07-2017 01:33 AM
my 3 hp Powermatic takes nearly that long to spin down as well. Larger motors carry more inertia and take longer to stop. In addition, check the belt tightness. If you are getting belt squeal on start up your belt is too loose, which will (counterintuitively) reduce the friction in the system allowing it to spin down longer.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
MrUnix
#14 posted 08-07-2017 01:58 AM
- TungOil
31 seconds? That is excessive. My 3hp Baldor takes about 7-8 seconds to come to a stop – and it’s a three phase motor, which will usually take a bit longer than a single phase one. You can see it here.
TungOil
#15 posted 08-07-2017 02:11 AM
In my experience a single phase motor typically weighs more that a comparable 3 phase motor. The extra weight is in the armature, which gives it more inertia, so all other things being equal it will spin longer.
showing 1 through 15 of 32 replies
