"Vise Assembly" on the Miter Saw?
Forum topic by skone posted 862 days ago 1406 views 0 times favorited 12 replies Add to Favorites Watch
View skone's profile
skone
144 posts in 971 days
862 days ago
Greetings, all. I’ve got a number of saws. Never had a miter saw, though — until today. Today is my bday and believe it or not, craigslist came through for me with a very nice Hitachi C10FCE2 10” Compound Miter Saw. $50. Isn’t that something? Today’s buy was great for a number of reasons. Price (!!! wouldn’t you agree?). Also, learning more, stepping up the game and being able to make 45˚ cuts that are… actually… 45˚.
The saw I purchased is missing one thing and that is the “Vise Assembly”. It appears to be a simple screw/knob contraption for holding the work down, “hands free”. While hands free sounds safe, in youTube vids and whatnot, I’ve never seen anyone use such a thing. I see everyone using their hands to hold the work.
My QUESTION to you miter saw operating veterans is this:
What do you do? Vise? Clamp? Hands? Did your saw come with such a vise? Do you use it? If this was your ‘new’ saw, would you order the ‘Vise Assembly” from Hitachi parts?
Thanks in advance, everyone.
-- "Take extra care not to lose what you feel" (Winwood/Capaldi/Wood)
12 replies so far
View richgreer's profile
richgreer
4474 posts in 1240 days
#1 posted 862 days ago
My miter saw (Makita LS1013) has, IMO, too short of a fence. I attached 1/2” boards to the fence and, effectively, raised the height of the fence. When I did that, I rendered the vise inoperative. It will not work over that taller fence.
I knew that would happen when I added the boards and I was okay with that. With my previous miter saw I virtually never used the vise. 95% of the time I just set a board on the miter saw, hold it in place with one hand and run the saw with the other. Every once in a while I want to do something that requires clamping something in place. I’m always able rig something up.
In my opinion, a miter saw is not the right choice when working on small items that may require you to have your fingers close to the blade.
All that to say that not having a vise would be for me, no big deal.
Craftsman on the lake
2020 posts in 1604 days
#2 posted 862 days ago
My Bosch has that screw lever thing that holds work down. Usually I don’t use it but if I have a small piece I’ll use that or clamp it some other way to keep it still till I cut it.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://gagnerwebsite.com/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
View cabmaker's profile
cabmaker
1022 posts in 975 days
#3 posted 862 days ago
No vise (clamp) here.
27262 posts in 1988 days
#4 posted 862 days ago
Skone, I have a 10” Hitachi slider and it did come with a hold down. I only use it on rare occasions. Most of the time it sits in the cabinet on which I have the saw mounted. If I did not have one on my saw I really would not miss it.
View newbiewoodworker's profile
newbiewoodworker
659 posts in 993 days
#5 posted 862 days ago
Honestly, I just use what I learned: My hand.
My clamp, is only used for bevels. But for 90s I perfer merely to hold it. I can hold it closer to the blade(I won’t lie: I occasionally hold it as close as 2-3inches… And not to mention, its easier to keep long stock from falling on the floor, by holding it. Although, it occasionally helps with cut-offs… although, it never completely helps.
-- "Ah, So your not really a newbie, but a I betterbie."
12048 posts in 1507 days
#6 posted 862 days ago
never used it
if i have to cut small pieces
i get another block
(same thickness as the on i want to cut
further away
and put a ‘plank’ over both of them
making a ‘bridge’ over them
and push down on it
it holds the small piece to be cut
skone
#7 posted 861 days ago
thanks for the replies, everyone. the trend is clear to me and particularly here on LJ, majority rules. i appreciate the help.
View TheDane's profile (online now)
TheDane
2672 posts in 1829 days
#8 posted 861 days ago
Mine has a screw clamp that drops into a dog hole on either side of the saw deck so you can tighten the workpiece to the fence. I use it occasionally, but more often than not, I just use Irwin QuickGrip clamps.
—Gerry
View Cosmicsniper's profile
Cosmicsniper
2147 posts in 1324 days
#9 posted 861 days ago
I should use mine more than I do (for short cuts), but i certainly use it to true up stacked boards…I don’t have a station with long fence so I can’t utilize a stop for repeatable cuts.
-- jay, www.allaboutastro.com
View Lumber2Sawdust's profile
Lumber2Sawdust
112 posts in 1031 days
#10 posted 861 days ago
I also have a Hitachi saw, and like everyone else, I don’t use it. It is way to slow to do anything efficiently. It may be handy to hold a stop block, but as Rich said, there are other ways to do that, too.
I suspect the reason the miter saws come with the clamp is so the manufacturer can specify to use it whenever you cut something. Then, if you cut off a finger, the first question would be “did you use the clamp?”. If you say no, it’s your fault for not using the provided safety features.
Maybe I’m a little cynical about things like that…
View Gene Howe's profile (online now)
Gene Howe
3181 posts in 1594 days
#11 posted 861 days ago
My best use of the clamp is when making multiples of the same length. I line up the first cut on my pencil line, tighten the clamp, set the stop block and cut.
skone
#12 posted 846 days ago
Thanks again for all your help guys. I will surely be devising a clamp system when the need arises—but for now, not in a hurry. I put together a stand for the saw today. Post is titled “The $25 Miter Saw Stand”... if you’re curious. Bare bones but perfect for the time being—at my budget and skill level.
