House advice
« back to Coffee Lounge forum
Forum topic by JCamp posted 08-05-2017 12:44 AM 415 views 0 times favorited 3 replies Add to Favorites Watch
View JCamp's profile
JCamp
785 posts in 632 days
08-05-2017 12:44 AM
We just sold our house that I’d been fixing up for the last 5 years. It was a beast of a project…. but now on to the next!
We are going to b buying a home that’s around 50years old. The siding An roof are probably 20years old and will need replaced in a few years but I’m not wanting to throw that much money at fixing it up right now.
There are several holes in the siding about this size. Anyway to fix them to where they’ll look less noticeable without residing the hole house right now?
also the roof has some dark spots like stains on it. Anyway to remove them?
-- Whatsoever thy hand findeth to do, do it with all thy might
3 replies so far
JCamp
#1 posted 08-05-2017 12:52 AM
Also the garage was changed to b a residence at one point It has some ugly brown cabinets in the “kitchen” area
Is there a good (fast/cheap) to remove the dark brown finish?
View ClayandNancy's profile
ClayandNancy
519 posts in 3096 days
#2 posted 08-05-2017 02:30 AM
You can just replace that one piece of siding. Only problem is matching the color due to fade. As to the roof that’s probably algae. They have a spray bottle that attaches to your hose and has a algae killer in it. Home Depot has it ,sorry can’t remember the name but it works great. Sprayed my roof and the black disappeared after a month or two. Paint the cabinets easiest fix.
117165 posts in 3658 days
#3 posted 08-05-2017 02:53 AM
J fixing Vinyl siding is a fairly easy to fix as Clay and Nancy said matching the color and style can be kind of tough, sometimes you can steal some from a hidden part of the house(behind bushes etc.) and use some new siding of another color until you re-side the whole house. Re the roof it could be just dirt from leaves laying there or as said above algae, mold ect. Trying cleaning it first and see if that does the trick, perhaps a little bleach water and a brush? Looking at the roof it looks like it may have bubbled areas that are coming loose ,it could be poor installation or it may not be vented properly. The quickest way to change the cabinets is to paint them other wise you will have to strip them and restain. Just a guess from a 30 year contractor.
