Sharpening Bench Chisels
« back to Hand Tools forum
Forum topic by JPrictoe posted 08-04-2017 01:47 PM 877 views 0 times favorited 12 replies Add to Favorites Watch
View JPrictoe's profile
JPrictoe
1 post in 337 days
08-04-2017 01:47 PM
Topic tags/keywords: sharpening chisel whetstone
First timer. I bought a whetstone (1000/4000) to put an initial grind on a very cheap chisel from the big orange box. It did not go very well. Flattening the back is pretty intuitive, but when shaping the bevel, I burrowed a trough in the stone that I now realize I need a flattening stone to maintain and even out.
My question is: Should I buy a flattening plate and continue to buy whetstones? Or is there a more cost effective way to sharpen chisels (money is a priority)?
12 replies so far
View waho6o9's profile
waho6o9
8191 posts in 2577 days
#1 posted 08-04-2017 01:50 PM
Atoma diamond plates will save you time and money.
Welcome to Lumberjocks JPrictoe
View Carloz's profile
Carloz
1147 posts in 592 days
#2 posted 08-04-2017 01:59 PM
you can start with a set of sandpapers and a flat hard surface, like a piece of glass or a stone tile from the same orange store you bought you chisel from. Often it all you need, If with time you feel you overgrown it you will have a better idea what you need,
View JayT's profile
JayT
5633 posts in 2211 days
#3 posted 08-04-2017 02:39 PM
You can flatten your stone with some coarse sandpaper on a flat surface instead of buying a flattening plate. That can be a piece of granite, a table saw top, a jointer bed or whatever else you have have that is reasonably flat. I’ve even heard of some people flattening stones on a concrete block.
Cost effective is relative. Sandpaper on a flat surface is the cheapest way to sharpen in the short term, but the costs add up quickly if you are doing much sharpening and it ends up being the most expensive system in the long run. Good quality diamond plates have the highest up front cost, but are generally the lowest cost over their life because they last so long. Oil stones and water stones fall somewhere in between. Which system is going to be best for you depends on a variety of factors, such as how often you sharpen, what kind of steel is used and what your work environment and flow looks like.
Smitty_Cabinetshop
15353 posts in 2619 days
#4 posted 08-04-2017 02:49 PM
DMT diamond stones are effective.
JayT speaks truth, so does Carloz.
Moving to 1000/4000 for an ‘initial grind’ doesn’t sound right to me. Usually a less fine series of grits is followed. So you might be trying to do too much with you fine stones.
View onoitsmatt's profile
onoitsmatt
392 posts in 1176 days
#5 posted 08-04-2017 02:49 PM
If money is a priority keep your current stones. As others have said, you can adhere sandpaper to a flat surface and flatten the stones on that. If you are digging into the stone when honing the bevel you can spend $15 on a cheap honing guide or apply pressure only on the pull and not on the push when honing. If you are new to sharpening, the honing guide may be a good bet.
-- Matt - Phoenix, AZ
View Vindex's profile
Vindex
91 posts in 822 days
#6 posted 08-04-2017 02:57 PM
I only have these two stones:
-DMT 11.5 coarse diamond stone
-King 1000/6000 combination stone
The DMT stone sets my bevels and flattens the waterstone. I use sandpaper attached to melamine with a spray adhesive if I need a coarser grit than the DMT has.
View Lemwise's profile
Lemwise
75 posts in 617 days
#7 posted 08-04-2017 07:16 PM
- waho6o9
Couldn’t agree more. I’ve switched to Atoma plates (600 and 1200) after years of using water stones and I’m never going back. They’re faster, they stay flat and if you use them the right way they should last you at least 10 years.
View Andre's profile
Andre
1839 posts in 1806 days
#8 posted 08-05-2017 06:32 AM
I hollow grind my blades, 1000 Water stone then right to 8000 for the polish. To touch up couple of passes over the 8000 stone or a flat hardwood block or even MDF with some green compound gives a new fresh edge quickly. Have found that with better quality blades(PMV-11) touch ups are very infrequent. Have never found a Diamond stone that could give the same polish? Have to watch as A1, O2 and PMV-11 blades all polish slightly different.
View harley090's profile
harley090
1 post in 290 days
#9 posted 08-10-2017 04:54 AM
I think that buying a flattening plate is a good choice.
View HorizontalMike's profile
HorizontalMike
7757 posts in 2914 days
#10 posted 08-10-2017 10:11 AM
I posted this review some 4-1/2yr ago, and since then mine is still going strong. I can and do sharpen chisels, plane blades/cutters, and my lathe tools. This probably the cheapest “best” long term solution out there. The polishing wheel, when used with a 10,000 grit polishing stick easily brings up a mirror finish. Check it out below:
Harbor Freight 4×36 Belt Sander
View Bluenote38's profile
Bluenote38
257 posts in 389 days
#11 posted 08-10-2017 12:00 PM
- HorizontalMike
What kind of belt are you using? Type and grit.
-- Bill - Rochester MI
HorizontalMike
#12 posted 08-10-2017 05:09 PM
Oops, forgot the link to my review…
http://lumberjocks.com/reviews/product/3110
180 grit is more than enough, and sharpens much finer than it would by hand. The spinning belt basically makes it act like a finer grit.
