Finished walnut not shiny enough for client
Forum topic by shoichi posted 08-04-2017 08:40 AM 1669 views 0 times favorited 4 replies Add to Favorites Watch
View shoichi's profile
shoichi
30 posts in 1101 days
08-04-2017 08:40 AM
So I just finished my first major table for a client and would like to give them a product or something they can rub on the table to keep it nice and shiny. I finished the table with 5 coats of equal parts of boiled linseed oil and raw tung oil and poly. Is there a cream or a conditioner or something they can hand rub on the table to keep it nice and shiny and fresh looking?? Thanks
View Gilley23's profile
Gilley23
489 posts in 621 days
#1 posted 08-04-2017 10:27 AM
So is the table not shiny enough or are you trying to maintain the finish?
View Bill White's profile
Bill White
5149 posts in 4199 days
#2 posted 08-04-2017 11:08 AM
An automotive rubbing compound will polish the table. Maguire’s makes some good stuff. Rub out and wax (not auto wax).
Bill
-- bill@magraphics.us
View OSU55's profile
OSU55
2033 posts in 2229 days
#3 posted 08-04-2017 11:14 AM
With the concoction used I doubt there is much of a film thickness to be rubbed out. Putting some coats of just poly will add sheen and build film thickness which can then be rubbed for desired sheen.
View Gene Howe's profile
Gene Howe
11160 posts in 3668 days
#4 posted 08-04-2017 11:50 AM
OSU55 is right on. I use a similar concoction but just a 50/50 mix of oil and poly for the first coat. Then reduce the oil by 50% for each succeeding coat. Usually, for items that will see lots of use, a couple final coats of straight poly. With light sanding between coats. To finish it off, a rub down with Johnson and Johnson paste wax applied with pads of Liberon wool.
