Jet 14" Bandsaw fence not square to table, ideas on aligning?
Forum topic by PatrickIrish posted 08-04-2017 06:48 AM 2024 views 0 times favorited 3 replies Add to Favorites Watch
View PatrickIrish's profile
PatrickIrish
131 posts in 2284 days
08-04-2017 06:48 AM
I picked up a used 14” Jet bandsaw while back. Cuts great but I noticed the fence if measured in the front and back to the miter slot are not the same. It out about a 1/8” in back (behind the blade).
I thought it was a fence issue so I bought and installed the kreg fence. Still out.
Jets manual doesn’t really say how to fix that or I could be reading it wrong
Don’t I want the fence to measure the same the miter slot anywhere along the fence? How do I do this? I’m thinking the trunnions bolts need to be loosened and the table moved a little.
3 replies so far
View MrUnix's profile
MrUnix
7106 posts in 2437 days
#1 posted 08-04-2017 07:11 AM
Ummm… the fence attaches to the table, right? So loosening the trunnions and moving the table won’t accomplish much. There should be a way to align the fence itself, however I don’t have one as a reference, so I can’t help you with that. But IMO, it’s not all that important. Heck, I have a POS homemade fence I scavenged off an old Ohio Forge benchtop table saw, and made rails from left-over table mounting angle iron from a RAS upgrade.
My fence is certainly not parallel to anything, but it still cuts just fine and re-sawing still comes out great. The unimportance of being dead-nuts parallel to the blade/miter slot is even shown in the obligatory band saw tune up video – where he deliberately kicks the fence out of whack and still is able to re-saw a nice thin slice:
Band Saw Clinic with Alex Snodgrass
(Fence stuff is about 15 minutes into the video if you want to skip ahead)
View Sparks500's profile
Sparks500
207 posts in 569 days
#2 posted 08-04-2017 12:19 PM
Bandsaws never cut square with the table. you have to set the fence for blade drift.
https://www.youtube.com/watch?v=IZThUPOr_Ug
-- A good day is any day that you're alive....
View jdh122's profile
jdh122
1058 posts in 3056 days
#3 posted 08-04-2017 12:31 PM
A lot of people argue that with new blade-making techniques there hsould be no need to adjust for drift with a properly set-up bandsaw (mandatory reference here to Snodgrass video: https://www.youtube.com/watch?v=wGbZqWac0jU)
Whatever the case, it certainly isn’t as important to have fence line up with the blade as it is with a tablesaw. If, as you say, the saw cuts great I,d probably leave it alone. But if you want to adjust it you can probably shim the fence rails out on one side or the other.
-- Jeremy, in the Acadian forests
