What finish to put on aluminum?
Forum topic by Blake posted 01-07-2011 04:24 AM 4352 views 0 times favorited 15 replies Add to Favorites Watch
View Blake's profile
Blake
3443 posts in 3896 days
01-07-2011 04:24 AM
Topic tags/keywords: aluminum finish question
I asked my finishing guy if he could clear-coat the aluminum pulls I had custom made for my Credenza. He said he has had really bad luck with any kind of clear-coat on aluminum and he didn’t want to do it. I was kind of surprised since he does automotive stuff too. I wanted to put something on them to protect them and soften the cold metallic feel. Any suggestions?
-- Happy woodworking!
15 replies so far
View Loren's profile
10476 posts in 3670 days
#1 posted 01-07-2011 04:38 AM
You can get them anodized.
I wouldn’t expect much durability for a clear finish an aluminum,
but you might try brass lacquer, which sticks pretty well to trumpets.
You might want to look at gun finishing compounds for aluminum: http://sport.birchwoodcasey.com/Finishing/FinishingList.aspx?CategoryID=735f46a9-9bec-4146-bb28-3ad829ba4b04
Not my area of expertise at all. The guys who like to make new electric
guitar pickups and hardware look old have a lot of methods you may
want to look into.
View Steven H's profile
Steven H
1117 posts in 3082 days
#2 posted 01-07-2011 05:13 AM
Not recommended, because any clear coats will not last long. You might as well polish it.
Steven H
#3 posted 01-07-2011 05:14 AM
By the way, I love the handles.
Are they screwed with those machine s screws from behind?
View TopamaxSurvivor's profile (online now)
TopamaxSurvivor
18283 posts in 3698 days
#4 posted 01-07-2011 10:37 AM
Most gun finishes will wear off where they are handled on a regular basis.
View tdv's profile
tdv
1188 posts in 3092 days
#5 posted 01-07-2011 12:46 PM
I have used a special clear coat lacquer for brass but it doesnt last when polished or handled regularly it then shows discoloured patches where it oxidises on the worn off areas I would personally agree with Loren get them anodised. You went a long way to make it a nice job, anything less is spoiling the ship for a ha’peth (that’s a half penny worth) of tar as we say in Yorkshire.
Cheers
Trevor
-- God created wood that we may create. Trevor East Yorkshire UK
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2878 days
#6 posted 01-07-2011 12:59 PM
Blake,
I would Anodise them.
I’ve sprayed clear from an aerosol before and it looked fine. That was out of reach though.
However all handles need to be anodised as they get wear .
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View CharleyL's profile
CharleyL
222 posts in 3386 days
#7 posted 01-09-2011 06:19 PM
Anodizing will last better than any other surface treatment available. It is a process of oxidizing the surface to form a hard aluminum oxide coating. Since the oxide is a thin and very hard surface it will resist wear very well. The process will also dull the mirrored shine a bit. This oxide can be clear, or dyed many different colors and the dye sealed into the oxide surface during the anodizing process, if you should decide that a color is preferred over the look of the dulled anodized aluminum appearance. Black, red, and gold are common colors, but many others are available. Search for an anodizing company in your area and talk to them about what options are available.
Charley
View jeepturner's profile
jeepturner
939 posts in 2814 days
#8 posted 01-09-2011 06:25 PM
X4 or 5 on the anodizing. I work in aerospace and that is the first finish requirement on most aluminum. After you anodize then you might have better luck with a clear coat, but with the anodized coatings available you may not want a top coat.
-- Mel,
View racerglen's profile
racerglen
3112 posts in 2802 days
#9 posted 01-09-2011 09:29 PM
HHmm.. Check with the people who doo aluminum wheels with a clear coat..but the anodizing does seem to be the most durable . Even though after 265 thousand km my Jimmies’s wheels only have a few spots that could use repair.
-- Glen, B.C. Canada
View BTKS's profile
BTKS
1986 posts in 3486 days
#10 posted 01-11-2011 02:17 AM
Don’t have a clue about finishing aluminum but I really like the look these pulls.
BTKS
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View ghazard's profile
ghazard
382 posts in 3532 days
#11 posted 01-11-2011 04:35 AM
Definitely anodize if you want a long term finish that cleans up well for a long time.
Good luck
Greg
-- "Hey, you dang woodchucks! Quit chuckin' my wood!"
View 8iowa's profile
8iowa
1580 posts in 3783 days
#12 posted 01-11-2011 05:08 AM
Give Johnson’s past wax a try. (original formula with red stripe on can) It is easy to renew the wax coat from time to time and the wax will do a good job of resisting oxidation.
View KnotWright's profile
KnotWright
258 posts in 3510 days
#13 posted 01-11-2011 05:24 AM
Blake, I own an antique fire truck with aluminum running boards, what I did was a search on polish and Air Stream travel trailers. There are a lot of products out there to polish and protect aluminum. These polishes are also used on a lot of airplanes as well.
Depending on the “feel” you are looking to achieve, anodizing might be the cheapest, longest lasting option for you. The polishes are pretty expensive and labor intensive too.
-- James
View Edwin's profile
Edwin
139 posts in 3020 days
#14 posted 01-15-2011 09:55 PM
I build aluminum railings and had many powdercoated with great success. I live on the east coast in southern section of NJ with our harsh winters etc.. You can get A myiad of colors Ranging from flatblack to to international orange. I would goggle Powdercoating and explore…..............ED
-- Ed Port Republic
View grosa's profile
grosa
1004 posts in 2851 days
#15 posted 02-12-2011 04:21 PM
For indoor use I use lacquer.
-- Have a great day.
