How to use a jointer
Forum topic by agallant posted 01-07-2011 03:19 AM 2397 views 1 time favorited 4 replies Add to Favorites Watch
View agallant's profile
agallant
551 posts in 2910 days
01-07-2011 03:19 AM
Can someone explain to me the proper way to use a jointer? every time I use mine the ends of the board come up shorter when I put my strait edge on it.
View mathom7's profile
mathom7
69 posts in 2934 days
#1 posted 01-07-2011 03:29 AM
The wood whisperer did a couple video posts on this, I thought he summed it up nice.
This is the one to start on, make sure it’s set up correct first.
http://thewoodwhisperer.com/jointer-setup/
View live4ever's profile
live4ever
983 posts in 3033 days
#2 posted 01-07-2011 04:40 AM
Sounds like the outfeed table may be too low relative to the knives. The video linked by mathom7 is excellent for making sure your jointer is setup properly.
As far as technique goes, make sure to transfer pressure to outfeed side of your board as soon as enough wood has passed the cutterhead, and keep downward pressure on the outfeed side from that point onwards.
View TomHintz's profile
TomHintz
207 posts in 3421 days
#3 posted 01-07-2011 10:47 AM
I have a few stories on setting up and using the jointer at the link below, scroll down to the Jointer section. The jointer looks like such a simple machine but in reality it is very technique sensitive. It can take a while to get used to even after you get it set up right. Practice is important so give yourself some time!
Jointer Stories
-- Tom Hintz, www.newwoodworker.com
View Russ's profile
Russ
357 posts in 3100 days
#4 posted 01-08-2011 04:17 AM
I second the Wood Whisperer episode as it is very educational.
-- Russ
