Cutting Tenons on the TS
Forum topic by Joel J posted 08-03-2017 10:49 PM 575 views 0 times favorited 5 replies Add to Favorites Watch
View Joel J's profile
Joel J
48 posts in 2023 days
08-03-2017 10:49 PM
I am wanting to cut some 1/4” wide/thick tenons in cedar fence picket material. The problem is that the rough sawn cedar is not all the same thickness. I was wondering if I could stack two table saw blades together with a 1/4” worth of washers and create essentially a “dado” blade that would cut 1/4” tenons. Or, does anyone have any other ideas? I am building some small rough sawn table displays for a wedding reception and think tenons would be the easiest way to join two pieces of materials together for this application. Thanks
-- Joel, Denver, CO
5 replies so far
View Loren's profile
10477 posts in 3732 days
#1 posted 08-03-2017 11:17 PM
The technique you describe is doable and
described in various books I’ve read.
http://forums.finewoodworking.com/fine-woodworking-knots/jigs-fixtures-tips-tricks/table-saw-tenon-spacers
Whether you want to go to the hassle of
fine-tuning the spacing to match your mortising
tool is another matter.
View Rich's profile
Rich
3342 posts in 673 days
#2 posted 08-04-2017 01:00 AM
As long as you reference the same face for both cuts, it won’t matter. Just mark one face of each board with a pencil, crayon, tape or whatever and make your cuts in relation to it. You’ll have to readjust whatever jig you’re using for the second cut. Use a piece of scrap for setting up each cut before doing the production pieces.
View TungOil's profile
TungOil
994 posts in 579 days
#3 posted 08-04-2017 01:00 AM
Assuming you are using a tenoning jig, it could be done with two passes on the TS, always referencing off the same face of the part being tenoned. First pass- cut all the right cheeks. Reset the blade, then second pass- cut all the left cheeks. Your tenons will all be equal thickness now, but you will have the potential for some variation on one side of the part.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
#4 posted 08-04-2017 01:07 AM
I used a tenon jig like this one for awhile.
It was easy to make and referenced off the
fence so adjusting for cut 2 was as simple
as moving the fence over. Design by
Frank Klausz.
Joel J
#5 posted 08-06-2017 05:47 PM
Great insight….thanks for all the input!
-- Joel, Denver, CO
