Minimum Laminate Radius
Forum topic by greg48 posted 01-06-2011 05:25 AM 6428 views 2 times favorited 6 replies Add to Favorites Watch
View greg48's profile
greg48
608 posts in 2874 days
01-06-2011 05:25 AM
Topic tags/keywords: question laminate
I’m building a simple play table and chair for my grand daughter; I wish to laminate the top and sides of the tabletop with a laminate. Question is: can I bend and glue the laminate around a 1” radius corner, or should I plan to make the radius larger? My table overhang is 3” from the leg/apron and the tabletop thickness is 1 1/2” around the perimeter.
-- Greg, No. Cal. - "Gaudete in Domino Semper"
View cabmaker's profile
cabmaker
1740 posts in 2925 days
#1 posted 01-06-2011 05:46 AM
It is doable for sure. If you are using a standard grade lam. (.065) You will be happier with a 1 1/2 inch min. radius. You will also want to use a heat gun or at least a blow dryer on high to warm up the area to be bent and warm alittle beyond the tangient point as well. You may also want to sand the backside (bend area) to thin it up a bit. NOTE: A typical kitchen counter top with radius corners will usually be a 1 1/2 R. Without heating you might crack 3 out of five attempts using standard grade. Results do vary with manufacturer of lam. Good luk JB
View j_olsen's profile
j_olsen
155 posts in 3288 days
#2 posted 01-06-2011 05:55 AM
Like cabmaker said—it’s doable with with horizontal grade but you could go with verticle grade which is 1/32 but I would stick with the 1 1/2” radius or you’ll run into the cracking issue
-- Jeff - Bell Buckle, TN
View ND2ELK's profile
ND2ELK
13495 posts in 3890 days
#3 posted 01-06-2011 06:10 AM
We did it all the time by using a heat gun. Keep the gun moving and make rub stick. Take a 3/4”T X 1 1/2”W X 8”L piece of oak and make a gradual taper on one end about 2-3” long. Use this to rub the laminate around the corner. Use a wider piece of laminate and rout off the access.
-- Mc Bridge Cabinets, Iowa
View Kjuly's profile
Kjuly
308 posts in 3402 days
#4 posted 01-06-2011 03:50 PM
Hi Greg,
Heating the laminate is pretty easy but do a few test runs on scrap material because you can over heat it and end up with bubbles and cracks. As mentioned above….keep your heat gun or hair dryer moving.
A trick is to use paraffin wax as a heat indicator. Using the wax, make short lines spaced about an inch apart, the length of the bend.
As you apply the heat, the melting wax will give you a good indication on your progress.
Mineral spirits will easily clean off the wax.
Keith
-- Keith, Charlotte, MI www.julyswoodworks.com
greg48
#5 posted 01-08-2011 06:53 AM
I wish to thank you all for your response. You have saved me many hours of trial & error learning as well as some poorly chosen words that I would regret. Thank you all again
View Nomad62's profile
Nomad62
726 posts in 3074 days
#6 posted 01-10-2011 07:28 PM
1” is a tight turn, but doable. It may be a good idea to steam it up some to soften up the fibers.
