trying to rout a groove on all 4 sides of a board 10 x 10 for a chese board
Forum topic by wiser1934 posted 08-03-2017 03:58 AM 414 views 0 times favorited 1 reply Add to Favorites Watch
View wiser1934's profile
wiser1934
524 posts in 3261 days
08-03-2017 03:58 AM
Topic tags/keywords: cheese board cherry
i want to make a 4 sided cheese board with a raised center for the cheese. going to finish the outside withe narrow rail to hold crackers in place. any ideas on the best way to rout the groove??? thank you for any help
-- wiser1934, new york
1 reply so far
View waho6o9's profile
waho6o9
8343 posts in 2691 days
#1 posted 08-03-2017 04:07 AM
I would lay out your lines for your grooves where you want them and then use a plunge
router to cut the grooves. I like using a straight edge to keep the router on course.
If you plunge cut the corners first it saves time on sanding.
