Miter Fold Drawer Strength?
Forum topic by Jeff8529 posted 08-02-2017 01:21 PM 692 views 0 times favorited 7 replies Add to Favorites Watch
View Jeff8529's profile
Jeff8529
4 posts in 352 days
08-02-2017 01:21 PM
Topic tags/keywords: miter fold drawers cabinets rockler tradition tablesaw blade
I’ve been considering this new Miter Fold Dado set from Rockler: http://www.rockler.com/rockler-miter-fold-dado-set?sid=v9100&gclid=EAIaIQobChMIlrvSx8y31QIVS5V-Ch03kAOTEAAYAiAAEgIaYvD_BwE
How do you think cabinet drawers (kitchen) would compare in strength to traditional drawer construction methods?
(I did see the video of Andrew standing on one, but that was in the abstract, without a side-by-side comparison.)
7 replies so far
View Gene Howe's profile
Gene Howe
10535 posts in 3454 days
#1 posted 08-02-2017 01:34 PM
With all the glue surface available, that joint should be very strong.
View splintergroup's profile
splintergroup
2075 posts in 1247 days
#2 posted 08-02-2017 03:02 PM
Lots of surface area, but it still is primarily end grain. A proper bottom panel glued into a rabbet along the front and sides (with consideration for expansion) would more or less make any weakness a non-issue.
The price for the blade set is high and you can do the same thing with a standard blade, but setup is tricky and this blade set look like it would make it very easy (a bonus if you plan on a lot of drawers!)
View magaoitin's profile
magaoitin
246 posts in 975 days
#3 posted 08-02-2017 03:09 PM
Depending on your definition/method of “traditional” drawer construction, I am guessing it will be on par with a standard rabbet constructed drawer as the glue area is similar. I would think it would be slightly “weaker” vs dovetail construction.
The real advantage to the miter fold dado is just that it is quicker and gives a nicer finished edge profile with a single cut. However when you get down to it, for a kitchen cabinet you will most likely be adding a drawer face to each box, so you will never see a corner connection that is a little bit cleaner than more traditional construction.
My 2 cents, or in this cast $350.
Is it really saving enough time to justify the cost? In a production cabinet shop making hundreds of boxes, it might be a cost saver. If I am a hobbyist or just working on my own cabinets and only making enough boxes for a single kitchen remodel, who cares if I save an hour on box construction?
-- Jeff ~ Tacoma Wa.
View bbasiaga's profile
bbasiaga
1234 posts in 2020 days
#4 posted 08-02-2017 06:38 PM
The guy who invented it did a YouTube video of a strength test. He stood on it, etc. Eventually kicked it apart. It seems strong enough for even a heavily loaded drawer.
Brian
View Loren's profile
10476 posts in 3673 days
#5 posted 08-02-2017 07:16 PM
I’m sure the boxes are pretty strong but
that’s not all there is to it with making drawers.
You have to consider hardware compatibility,
because concealed drawer slides are designed
for drawers with recessed bottoms. Also,
when cutting from sheets of plywood in
making small, shallow boxes the miter
folded drawer box may be cost effective,
but in making full-sized kitchen drawers it
may leave large pieces of plywood left over
due to the size of the blank. Making drawer
sides out of ripped plywood is nothing if
not economical. Miter folding the entire
drawer from one piece undermines the
economy of the 5-part drawer box.
View johnstoneb's profile
johnstoneb
2938 posts in 2198 days
#6 posted 08-02-2017 08:07 PM
It looks like a very expensive novelty. a solution in search of a problem.
-- Bruce, Boise, ID
View ArtMann's profile
ArtMann
950 posts in 841 days
#7 posted 08-03-2017 12:38 AM
As already mentioned, the joint is mostly end grain, which is inherently weak. It would be okay for plywood but absolutely not for solid material. It seems to me that the setup would be like the far superior lock miter joint – which is to say it isn’t worth it, in most cases.
