Adapting metal working lathe for wood turning
« back to Woodturning forum
Forum topic by Mainiac Matt posted 08-02-2017 01:24 AM 1073 views 0 times favorited 25 replies Add to Favorites Watch
View Mainiac Matt 's profile
Mainiac Matt
8028 posts in 2321 days
08-02-2017 01:24 AM
I’ve turned a couple small wood and plastic projects on my metal working lathe using metal cutting tools mounted in the quick release tool holders, but this restricts you to straight line cuts.
So I purchased a set of lathe chisels from PSI and set about to make a tool rest to use with the lathe. Here’s what I came up with…
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
25 replies so far
View Jerry's profile
Jerry
2631 posts in 1641 days
#1 posted 08-02-2017 02:24 AM
Nice one Matt!
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
View unbob's profile
unbob
810 posts in 1896 days
#2 posted 08-02-2017 04:55 AM
If you were good with an EtchaSketch when you were a kid, should be no problem working the crosslide and carriage hand wheel at the same time to form curves and radiuses on a work piece. Give it a try.
View Woodwrecker's profile
Woodwrecker
4148 posts in 3569 days
#3 posted 08-02-2017 06:12 AM
Always got the old noodle going Matt.
I like it.
-- Eric, central Florida / Utor praemia operibus duris
View MrUnix's profile
MrUnix
6695 posts in 2192 days
#4 posted 08-02-2017 07:00 AM
Nice work. What model lathe is that (looks sorta like a Shop Fox)? At one point, I did think about doing something similar on my South Bend, but wound up just buying a wood lathe instead :)
Mainiac Matt
#5 posted 08-02-2017 01:10 PM
- unbob
Bob,
It sounds like you have “turned the wheels” on a metal working lathe yourself, because the EtchaSketch analogy is spot on. I used to think I was pretty good on the EtchaSketch, and could do fairly smooth diagonal lines… but I have yet to find a way to salvage a botched turning by flipping it upside down and shaking it :^)
- MrUnix
Hey Brad, It’s a Grizzly 10×22 (you can see better pics on my stand build project if your interested)
Mainiac Matt
#6 posted 08-02-2017 01:11 PM
I think I now have a good reason to convert the lathe to variable speed (which I’ve always wanted to do)
View splintergroup's profile
splintergroup
2007 posts in 1215 days
#7 posted 08-02-2017 02:51 PM
Looks totally functional!
My only concern is the cantilevered mounting of the rest. If you get into bigger objects it may become a bit springy.
A metal lathe that size has been on my dream list since I was a kid 8^)
unbob
#8 posted 08-02-2017 04:09 PM
I don’t have a wood lathe because I have a metal lathe, I use a couple of pieces of tarp across the bedways to help keep dust from getting behind the carriage apron.
I don’t know how to use the wood lathe tools-I don’t have any. I pretty much cut wood on the lathe using cutters shaped for cutting aluminum, and use the same methods cutting plastic or soft metal.
Mainiac Matt
#9 posted 08-02-2017 05:45 PM
- splintergroup
That is a legit concern and one that I have as well. I made this using the shanks of long 3/4” dia. partially threaded bolts, and the rest is 10” long. It does spring a little, but most of that comes form 1/2” thick the aluminum block.
I’m thinking about machining another one that is not as long, from 3/4” aluminum stock.
View MrRon's profile
MrRon
4757 posts in 3236 days
#10 posted 08-02-2017 05:54 PM
I’m not so happy with using a metal lathe for turning wood. First, wood chips and dust will get into the workings of the lathe and compromise the accuracy. Second, the speeds are usually not fast enough for turning wood. I have a great old Sheldon metal working lathe, but for woodworking, I bought a wood lathe. I have on occasion, turned a piece of wood on the Sheldon, but I didn’t like the mess it made.There’s a saying; “use the right tool for the right purpose”. That I believe. A metal working lathe is a precision machine and should be treated with respect.
Mainiac Matt
#11 posted 08-02-2017 07:09 PM
- MrRon
I don’t disagree with your viewpoint, but I have limited space and funds and wanted a metal lathe more than a wood lathe, and made sure that I chose a model that went up to 2,000 RPM….
that said, putting a bib around the saddle will go a long ways to keeping it clean and if I fall in love with wood turning, I’m sure I’ll go in that direction.
I doubt I’ll ever use any of my tools enough to wear them out… (accept for my SCMS… which is 22 years old and has built a house, a barn, a shed and dozens of shop projects…. but it keeps on kicking)
unbob
#12 posted 08-03-2017 01:57 AM
Complete nonsense, with reasonable care a metal lathe will not be damaged by cutting wood. I often see amateurs making goofy statements like that. As-metal cuttings are nasty, sharp and hot.
View msinc's profile
msinc
380 posts in 497 days
#13 posted 08-03-2017 06:53 AM
- unbob
I totally agree…if wood dust hurts your metal lathe what exactly do you think metal dust is going to do to it?? Let me say it another way, if a little bit of wood dust hurts your “precision” metal lathe then how much respect does it deserve?? Gimme a break!!!!
MrUnix
#14 posted 08-03-2017 07:20 AM
Wood chips/dust certainly won’t hurt a metal lathe… but mix that stuff with swarf and oil and it sure does become a mess!
Mainiac Matt
#15 posted 08-04-2017 03:02 AM
My only concern, aside from gumming up the lead screw, would be tannic acid in oak shavings causing rust.
But a good cleanup and wipe down with oil does wonders
