Question About Ashley Iles
« back to Woodcarving forum
Forum topic by SawMueller posted 08-01-2017 11:59 AM 1465 views 0 times favorited 8 replies Add to Favorites Watch
View SawMueller's profile
SawMueller
54 posts in 671 days
08-01-2017 11:59 AM
Topic tags/keywords: tools ashley iles carving
I recently purchased a V gouge and a small #5 gouge from an Ashley Iles seller. These are the first carving tools I’ve ever purchased, so I’m not quite sure what’s normal, but a couple things seemed odd to me.
1. The two tools arrived with the ends dipped in thick wax. It looked like the same wax used to seal green wood. Maybe it’s normal, but it seemed odd to me.
2. The V has a highpoint at the very bottom of the V, and had dust/shavings on it like it had been used previously.
3. The #5 has what appears to be a damaged/worn cutting edge.
I don’t remember what the site I ordered from specified, but with a top quality tool brand like Ashley Iles, I expected them to arrive in nearly ready to use condition. I have some Pfeil tools coming that specifically noted they come sharpened and ready for use (what I would expect from a top quality tool brand).
Are the items above of no concern, or did I get the short end of the stick a bit?
-- Dylan in St. Louis - SawMueller.com
8 replies so far
View RustyHacksaw's profile
RustyHacksaw
145 posts in 1503 days
#1 posted 08-01-2017 12:34 PM
Ashley Iles chisels come in wax. Iles chisels do not come Honed. Pfiel comes ground and honed, ready for use. Most everyone else expects you to hone them yourself, to your sharpening standards.
Your chisels are perfectly fine.
SawMueller
#2 posted 08-01-2017 12:42 PM
Oh ok, thanks! I expected to sharpen the edges a bit, but I was surprised that I’ll likely need to grind/shape the edge.
Any recommended tutorials or videos on how to properly form an edge? I’ve investigated sharpening to make sure I have a handle on that, but haven’t looked at the earlier forming processes yet.
View Aj2's profile
Aj2
1952 posts in 2037 days
#3 posted 08-01-2017 01:22 PM
85go I use Ashley lles carving chisels and yours do look a bit rough to me.But if they cut then I would use them as they are.Try to keep them cutting as long as possible by honing with strop a some type of compound.I use jewelers ruge but have several other too.
When I do need to reshape I use a Tormek and carefully do the work under good strong light with a magnifier.
My eyes are old :(. the real test is a cut across the grain of some baswood.It should be shiny clean and smooth with no defects.Hope this helps you continue good luck
-- Aj
SawMueller
#4 posted 08-01-2017 06:45 PM
Is this true? I was watching Mary May sharpen a V tool and she specifically warned against forming a horn.
“A properly sharpened parting tool does have a projection (horn) at the bottom of the V.  These are very hard to sharpen properly and AI tests each one before shipping.”
View knockknock's profile
knockknock
466 posts in 2412 days
#5 posted 08-02-2017 12:36 AM
A V-parting tool has three facets on the outside: a flat bevel on the left, a flat bevel on the right, and a flat on the bottom. When sharpening, sharpen each facet more or less evenly so that there is a nice even V edge on the inside. If you don’t work the flat on the bottom enough, it will stick out farther than the sides of the V (I think this is what is maybe what Mary May would call a horn?). If you work the flat on the bottom too much, the bottom of the V will recede and not meet the sides of the V. When dealing with the inside edge of the V (or any gouge), there are two ways. Some people like a small bevel on the inside. Others like me don’t and only work the inside edge enough to remove any burr from sharpening the outside bevel(s).
Pictures of my largest V-parting tool, showing the three outside facets, and no bevel on the inside of the V.
View Aj2's profile
Aj2
#6 posted 08-02-2017 12:39 AM
Now that’s a nicely shaped v gouge much bette than mine I think.
-- Aj
SawMueller
#7 posted 08-02-2017 01:40 PM
Thanks, that’s what I was envisioning. Mine has a good 1/32” or maybe even 1/16”, horn sticking out from the bottom. The customer service response was that a properly sharpened V should have a horn.
View mpounders's profile
mpounders
907 posts in 3134 days
#8 posted 08-07-2017 04:05 PM
Thanks, that s what I was envisioning. Mine has a good 1/32” or maybe even 1/16”, horn sticking out from the bottom. The customer service response was that a properly sharpened V should have a horn.
- 85GoCards
Uh, customer service is wrong! Still good tools, but sharpen it yourself or send it off for sharpening. It won’t have a horn on it when it returns!
-- Mike P., Arkansas, http://mikepounders.weebly.com
