2HP HF DC Stovepipe Modification, tweaks, and plan of attack
Forum topic by NBeener posted 01-05-2011 01:29 AM 6231 views 4 times favorited 46 replies Add to Favorites Watch
View NBeener's profile
NBeener
4816 posts in 3046 days
01-05-2011 01:29 AM
Topic tags/keywords: dust collection dust collector dc harbor freight harbor freight 2hp dc stovepipe modification dust collector improvements
Some of you have probably heard of the ”stovepipe modification” for the Harbor Freight 2HP Dust Collector.
Long story short … you replace the existing 5” flex hose (running FROM the impeller TO the housing that holds the filter and plastic collection bag) WITH 5” single-wall stovepipe and a couple of 5” 45 degree elbows.
It looks like this … all taped up with “proper” duct sealing tape:
Sealing other potential infiltration points:
While I’d definitely like to plumb my shop, and put 5” or 6” galvy throughout, with drops to all the machines, blast gates, etc., etc. —we’re likely to move within the next year. Not sure how adaptable this setup would be to the “next” setup….
So …. my current plan of attack….
I’m running WAY too much flex hose (originally, nearly 40’, in total), and it’s pulling too much efficiency out of my system, when you factor in the 30gal chip separator, too:
So … I’ve ….
- moved my chip separator MUCH closer to the DC
- replaced THAT 10’ flex hose run with 4” galvy duct, a couple of 45 degree elbows, and a couple of short lengths of flex hose at each end:
I’m going to ….
- put one more 4” 45 degree galvanized elbows the remaining (intake) port, on the chip separator lid, to ease the torque on the hose … that … makes it want to kink,
AND
- either .... live with my 4” 28’ long Rockler DustRight DC flex hose, for now, or …. replace IT with a couple lengths of 4” 26ga, galvanized duct, coupled together with a couple of short lengths of flex hose … to allow greater in-shop maneuverability to and between the power tools
- OR ... potentially … buy two blast gates for the Wye off of my DC, and then … run one port TO my chip separator (as described above), and … with the other port … bypass the chip separator, entirely, for the most CFM-demanding of the machines (ie, planer, jointer), using just enough flex hose.
Results:
The Placebo effect, on the suction, has been excellent so far !
Because I have a fair bit of time into this (and only a couple of bucks), I’ve convinced myself that these tweaks made a world of difference !
In truth …. there IS some difference. You get a sense for the suction at the end of the final hose … over time. I’m sure it’s a chunk better, now. Where it used to leave some shavings on the bed of my jointer and planer, now there are a scant few.
Using the “separator bypass” approach … running the hose straight from the DC to the planer/jointer … there are NO shavings left behind !
Cleaning up my act …. while I await the arrival of The Really Big Forstner Bit … to get the vise installed, and finish my workbench :-)
-- -- Neil
46 replies so far
9765 posts in 3520 days
#1 posted 01-05-2011 01:34 AM
Any workshop puttering that delivers a verifiable placebo effect
gets a thumbs up from me.
NBeener
#2 posted 01-05-2011 01:36 AM
LOL !
-- -- Neil
View SPalm's profile
SPalm
5310 posts in 3754 days
#3 posted 01-05-2011 01:45 AM
Good for you Neil. Every little bit helps.
All of a sudden I am singing “If I only had a heart, ta da, ta da, ta da”.
Thanks for the song. Not. So I thought I would put it in your head too.
Steve
-- -- I'm no rocket surgeon
View Eric_S's profile
Eric_S
1565 posts in 3068 days
#4 posted 01-05-2011 01:48 AM
Good idea Neil. I have a one tool at a time DC (Delta 50-720 CT) with a 10’ DustRight flex hose. I was debating if it was worth it to go to a straight run, but then it would be difficult to really move it around easily so I still have to think it through. I like your setup though.
-- - Eric Noblesville, IN
View Hoakie's profile
Hoakie
306 posts in 3908 days
#5 posted 01-05-2011 01:49 AM
Just a quick question….Is that a remote control Long Ranger you have on the DC? I have the one controlled by the blast gates but apparently the current draw is too large for the internal relay and it kept welding open after a while (at least the two I tried). If that model has worked for you, I’d be interested in trying it out.
-- John H. [To invent, you need a good imagination and a pile of junk. ~Edison]
View grizzman's profile
grizzman
7836 posts in 3176 days
#6 posted 01-05-2011 02:05 AM
all this talk about dust collection…yea right…you look close to this set up he has going….BOY HES RUNNIN MOON SHINE IN THAR….A I SMELL CORN LIQUOR IN THAR…...THAT AINT NO DUST COLLECTOR…thats a still.. move the camera over and you would see the copper pot…lol…....could not resist that one neil…....its sure looking good…by the time your done you will have a pretty good and efficient system…good job .
-- GRIZZMAN ...[''''']
NBeener
#7 posted 01-05-2011 02:16 AM
Steve: LOL ! It IS a bit of a tin man, isn’t it ?!
And … grizz .... one word for you, my friend:
Shhhhhhhhhhh.
That IS only one word, right ? ;-)
-- -- Neil
13594 posts in 3213 days
#8 posted 01-05-2011 02:30 AM
if it
sucks
that’s good !
View HorizontalMike's profile
HorizontalMike
7727 posts in 2786 days
#9 posted 01-05-2011 02:33 AM
Geez! I think this whole conversation sucks! LOL!
I am of the one tool DC at-a-time camp, and thus use the flex tube. The planer gets a 20’ run and the TS, BS, jointer, and router can all be reached with the same 10’ hose running to a Thien separator/HF-DC. One man shop and it only takes a few seconds to change the hose hook-up. No complaints.
View Mark's profile
Mark
1807 posts in 3146 days
#10 posted 01-05-2011 02:36 AM
neil, i feel like i’m watching the red green show with all that duct tape lol :P
-- M.K.
View Bothus's profile
Bothus
441 posts in 3049 days
#11 posted 01-05-2011 02:42 AM
That’s pretty cool Neil.
Just one question, I’ve used tons of duct tape in my life but I’ve never seen it used for taping ducts together, how did you ever come up with that idea? Shear genius!
Jerry
-- Jerry Boshear, Professional Kitchen Designer, amature woodworker.
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 3830 days
#12 posted 01-05-2011 02:51 AM
Wow Neil…any chance that rig could become “self aware” and attack you?
I wasn’t aware that flex hose robs efficiency from your dust collection..is it the ridges?
View Paul C.'s profile
Paul C.
154 posts in 3118 days
#13 posted 01-05-2011 03:38 AM
I replaced all my spiral duct with 4” pvc pipe, about 25 ft in all. I also took out all the 2.5 inch and reduced my 90 degree turns to 0. It made a heckuva difference. Like having a new DC. I only connect the cyclone between my ducting and the planer. That alone has made a world of difference.
This is not to say that I am not trying to figure out how to put a clearvue or an oneida in my shop, tho’
View jack1's profile
jack1
2094 posts in 3900 days
#14 posted 01-05-2011 04:08 AM
You would have make Rube Goldberg proud, (sniffs silently). Nice work.
Beginningwoodworker
13347 posts in 3545 days
#15 posted 01-05-2011 04:15 AM
Good idea, Neil.
showing 1 through 15 of 46 replies
