finish for honey locust table
Forum topic by okwoodshop posted 865 days ago 1041 views 0 times favorited 8 replies Add to Favorites Watch
View okwoodshop's profile
okwoodshop
386 posts in 1341 days
865 days ago
Topic tags/keywords: question
I would like to ask for advice on finishing a Table I made of Honey locust and walnut. I would like to keep the natural color as much as possible and polyurethane tends to give everything an amber tint. I still want good protection for the top though. HELP!
8 replies so far
View childress's profile
childress
835 posts in 1708 days
#1 posted 865 days ago
try some different finished on some test pieces. That will give you the best idea of what you’re looking for.
In general though, waterborne finished have the clearest appearance. While oil bases give that yellow/amber look.
-- Childress Woodworks
okwoodshop
#2 posted 865 days ago
good idea’ I noticed on your japanese coffee table you used a mixture of tung oil ,poly, and mineral spirits. Did you use water based poly? will it work with tung oil? How did this finish hold up? sorry about picking your brain.
27262 posts in 1988 days
#3 posted 865 days ago
To answer your question water base poly will not mix with tung oil, mineral spirits or oil base poly. It will provide excellent surface protection for the wood but will not appear as “warm” as an oil base topcoat. It does not get an amber/yellow tint with age like oil base poly (which is the reason that oil base products acquire an aged look to them and are much “warmer” in appearance).
View fussy's profile
fussy
963 posts in 1217 days
#4 posted 865 days ago
I vote with water-based poly/ A test by FWW came up with 2 winners; General Finishesa High Performance from Rockler, and Resistane Plus from Hoodfinishing.com.
Steve
childress
#5 posted 865 days ago
No okwoodshop, I did not use water based. As Scott said, they don’t mix. The finish is great and is holding up just fine. I guess the real test will be to see what it’s like in 10 or 15 years :)
View Lochlainn1066's profile
Lochlainn1066
138 posts in 944 days
#6 posted 864 days ago
Show some pics! I have lots of honey locust around here (too much!) and I love the way it looks.
I’ve used shellac and amber varnish both on bowls of HL and I like the way it deepens the red. Just keep it off of the yellow sapwood, it makes it really plastic looking.
If you don’t want the amber, any clear poly, oil or water, will work. Definitely try some test pieces first!
-- Nate, thegaragestudio.etsy.com
okwoodshop
#7 posted 864 days ago
I am goimg to have to wait till the weather warms up a bit before I can finish this so I will be testing some small pieces to see what I like.
Lochlainn1066
#8 posted 863 days ago
Wow, that is great!
