| Forum topic by SPalm | posted 867 days ago | 650 views | 0 times favorited | 11 replies | ![]() |
867 days ago |
Topic tags/keywords: tips I fixed a problem last night that ended up being caused by my own maintenance error. Afterward I thought I should share in my delight. This prompts me to ask if others have similar quick tips. Old or new, we may have forgotten and need to be reminded. My tablesaw fence lock-down had turned into a nightmare. It was hard to operate and even caused the fence to jump when I lowered the cam lever. The fix: Wax. I cleaned off the chrome cam and waxed it. I also lightly sanded the cam plate and waxed it too. Woohoo. What a difference. It now locks with finger pressure. I guess I should re-read the manual every now and then. Another one: I posted this in the tool review section but I will do it here again. The digital angle readout devices (Wixey) can be used in all sorts of ways. Clamp your miter gauge bar vertically in a vise, attach the Wixey to the side of the bar and zero it. Now you can set your miter gauge to any desired angle with precision. The little devices can also be used for accurate table tilting on the scrollsaw or bandsaw after you zeroed it while it was attached to the blade. Got Tips? -- -- I'm no rocket surgeon |
11 replies so far
#1 posted 867 days ago |
Merci Steve, -- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking. |
#2 posted 867 days ago |
Don’t feel too embarrassed Steve – I had to do the exact same thing to my ShopFox fence about a month ago. Damned thing just kept getting more difficult to open/close until it was just about non-functioning! I was getting really afraid of a defective part until I read the stupid manual – Doh! A quick spray of silicone and now it works like it just came out of the box! I also use my Wixey gauge ALL of the time – it’s one of the most important tools in my shop! Let’s see what a good use would be that you wouldn’t normally use it for…......... Oh yeah! A week or so ago I had to drill a hole at a five degree angle and since my drill press table doesn’t tilt, I usually just use a wedge under a board on one end to get the desired angle. All it takes is to lay the board flat on the press, zero out the gauge on top of the board, and then start tapping a wedge under one side or the other until it reads the proper angle and the locking it all down. Simple and super accurate! :-) Good topic! I’m looking forward to more responses to this! -bob -- Man is a tool-using Animal. Nowhere do you find him without tools; without tools he is nothing, with tools he is all. - Thomas Carlyle http://www.ffrf.org |
#3 posted 867 days ago |
Here’s one: Don’t use silicone in the shop. It can cause nasty orange peel on finishes. Once it gets in there, it can travel around easily. Don’t let your better half use Pledge around the house either if you ever want to refinish something. -Bob: not sure if your spray really contains silicone or not. WD40, for one, does not contain it. Steve -- -- I'm no rocket surgeon |
#4 posted 867 days ago |
Wow! Did not know that Steve – Thanks! And, luckily it wasn’t WD40 I was using, but a different spray lube that doesn’t contain silicon. Whew! I’ll be sure to check my cans from now on! -bob -- Man is a tool-using Animal. Nowhere do you find him without tools; without tools he is nothing, with tools he is all. - Thomas Carlyle http://www.ffrf.org |
#5 posted 867 days ago |
Sorry if I misled you, WD40 does not contain silicone. It seems like it would, but it does not. Looks like you done good then :) I did not know this either until I joined LJs. You can search on this site and find all kinds of bad words about silicone. Steve -- -- I'm no rocket surgeon |
#6 posted 867 days ago |
Some car products (make that a lot of car products) contain silicone. SO if you plan on using car products for polishing and waxing check to make sure it DOESN’T contain silicone. -- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware karson_morrison@bigfoot.com † |
#7 posted 867 days ago |
I dislike using rulers and tapes. I really don’t care what the MM or inch dimensions are. Consequently I use a lot of shop made story sticks. My favorite one is simply a few pieces of 3/4X1/8 aluminum stock and a small block I fashioned to hold two of the aluminum bars. The block holds a tee nut and a screw for holding the bars in place. Some saw blades and some router bits do not produce grooves or kerfs of a standard dimension. So, when gauging groove width for stringing or some other type of insert/inlay, I use a set of loose metal shims, graduated in thickness, that I found in an auto parts store. Same as above, I just set them against blade and bring the fence to them. In those cases, I leave a little to bring down with a card scraper. One could do the same with a good set of drill bits. I just find the shims easier to use. When the shims are not enough, I bring out the Laminate display chips and add them to the mix. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#8 posted 866 days ago |
Wow, you guys are full of good ideas. As a retired tool maker I use my digital calipers and Adjustable Parallel Sets, they are an easy way to set all kinds tools extremely accurately. -- Chuck Emery, Michigan, |
#9 posted 866 days ago |
On the measuring front, I find a set of those brass set-up bars is really handy. I can stack them in multiple configurations. Oh, and an old deck of playing cards comes in handy for a temporary shim. It can shim from a half inch to thousandths. -- -- I'm no rocket surgeon |
#10 posted 866 days ago |
The one tip I can offer has nothing to do with woodworking, but will add harmony to your lives; NEVER GO SHOPPING WITH YOUR WIFE. Thank you. Steve -- Steve in KY. 44 years so far with my lovely bride. Think I'll keep her. |
#11 posted 866 days ago |
In my job it seems that my company sees a need for me to have up to date business cards. Since I never give them out, I always have a box of cards left that are obsolete. I keep a box of them handy for shims, like the playing cards mentioned above. I learned this from Rob Cosman a couple weeks ago for spreading glue: go to an art supply store and find a painter's knife, or palette knife. They will be with the artist’s paint brushes and should cost < $6. It’s a little flexible steel blade, about 2-3” long with a small wooden handle. He squirts little glue straight from the bottle onto the blade and applies it to his dovetails. Fast, precise, and CLEAN! I bought one the next day at Michael’s. I wish I had it 2 weeks earlier when I was using a Q-tip to apply glue to box joints on a box! |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1530 |
3547 |
15767 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6156 |
