Cambering a plane blade
« back to Hand Tools forum
Forum topic by Woodywazza posted 07-31-2017 12:53 PM 581 views 0 times favorited 8 replies Add to Favorites Watch
View Woodywazza's profile
Woodywazza
10 posts in 500 days
07-31-2017 12:53 PM
Topic tags/keywords: plane blade cambering
This topic has probably been done to death over the years but I would like to get some direction please. I have a number of planes, from No7 to No4 and my sharpening technique with a honing guide gives them all a straight edge. Can anyone give me some guidance on how to camber the blades using honing guides or other technique/s. Would appreciate any help thanks.
-- Stand in the mess you made, smell the aroma of wood, nod and smile knowingly!
8 replies so far
View gargey's profile
gargey
1013 posts in 975 days
#1 posted 07-31-2017 01:39 PM
Do everything the same, but press hard on one side for a while.
Then do everything the same, but press hard on the other side for a while.
Slow going in the beginning as you have to chew through a lot of metal, but once its got some camber its easy to keep it that way.
View Bill_Steele's profile
Bill_Steele
451 posts in 1931 days
#2 posted 07-31-2017 02:46 PM
Here’s another option > http://www.veritastools.com/Products/Page.aspx?p=222
I’ve also heard of people who have some success by wrapping tape around the center of a flat roller honing guide.
View WayneC's profile
WayneC
13783 posts in 4296 days
#3 posted 07-31-2017 02:53 PM
It also depends on the level of camber. A scrub plane, you would more likely start with a grinder. Also a file is another option for easing corners.
View rwe2156's profile
rwe2156
3170 posts in 1680 days
#4 posted 07-31-2017 02:57 PM
The make various jigs, but IME sharpening a cambered iron is pretty easy by hand.
Smitty_Cabinetshop
15694 posts in 2817 days
#5 posted 07-31-2017 11:47 PM
Can’t explain it better than this:
http://www.popularwoodworking.com/woodworking-blogs/chris-schwarz-blog/camber-with-a-honing-guide
View bandit571's profile
bandit571
21744 posts in 2882 days
#6 posted 07-31-2017 11:52 PM
Use a sharpie to mark the radius of the camber you want on the back of the iron….Grind,dunk, grind, dunk until the line has been cut. Use a figure 8 pattern when using the stones, couple swipes on the back to keep it flat.
Schwarz & Underhill….Handplane essentials.
Woodywazza
#7 posted 08-01-2017 12:46 AM
Thank you for all the advice guys, much appreciated. This is why we sign up to sites like this – problems solved by experienced woodies worldwide instantly. ;)
View Don W's profile
Don W
19007 posts in 2767 days
#8 posted 08-03-2017 11:02 PM
I use a slightly modified approach to Bandits technique.
Grind, drink, grind drink.
