Tiny Hole Saw
Forum topic by Peter Oxley posted 896 days ago 3146 views 0 times favorited 14 replies Add to Favorites Watch
View Peter Oxley's profile
Peter Oxley
1424 posts in 2071 days
896 days ago
Topic tags/keywords: question hole saw
Imagine the shape a hole saw without a pilot bit would cut – a round slot. I need to cut a round slot .25” outside diameter and leave about a .222” post in the center.
I’ve been searching for tiny hole saws, with no luck. Does anyone know where to find tiny hole saws?
Alternately, I’ve been thinking about getting 1/4” thin-wall tube and cutting saw teeth in the end. Any thoughts?
-- http://www.peteroxley.com -- http://north40studios.etsy.com --
14 replies so far
View HoBoMoNK's profile
HoBoMoNK
1380 posts in 2324 days
#1 posted 896 days ago
Something like the following might work:
Lee Valley
-- 温故知新
View ptweedy's profile
ptweedy
75 posts in 1590 days
#2 posted 896 days ago
I think that makeing a hole saw with a piece of tubing is the right way to get the tool. Next, to position the saw, overlay a piece of material with a hole the correct dia. and clamp it down. Then drill.
View Dennisgrosen's profile
Dennisgrosen
10851 posts in 1312 days
#3 posted 896 days ago
Ptweedy :
I have used a simular way of duing it , thow instead of a saw made of tube
I used a normale holesaw for drills and did take the center drill out of the holesaw
I have seen a tubesaw used in a brace , he make the first copple of rounds backward
simular to when when you start anyother sawcuting
but how accurate it was I don´t know , I did looked at some distance
well get us updated with your little project there :-)
maybee you will come up with another solution
Dennis
View MrsN's profile
MrsN
920 posts in 1723 days
#4 posted 896 days ago
Would a plug cutter like Hobomonk suggested work?
-- ----- www.KNWoodworking.com ----- --
View richgreer's profile
richgreer
4472 posts in 1271 days
#5 posted 896 days ago
In theory, you could do this with a router and a circular template that router sets in. You would “walk” the router around the circular template. This would work a lot easier if you had a round bottom on your router.
Peter Oxley
#6 posted 896 days ago
Thanks for the feedback, everyone.
I must not have explained it very well. Plug cutters leave about a .125” gap. The smallest router bit I have is .125”, too. The slot I need is very narrow – about .014” (a .222” post in a .25” hole). I haven’t tried it, but a drinking straw might fit tightly in the round slot I’m trying to cut.
Maybe I should have started out by saying what was going in the slot: inking nibs.
View DaddyZ's profile
DaddyZ
2036 posts in 1237 days
#7 posted 896 days ago
Why not drill the Hole, then fill in with a dowel (Sanded down of course)
You could even leave a half moon shape if you wanted
Sorry Bentlyj Great minds etc ;)
Peter Oxley
#8 posted 896 days ago
I had thought of gluing in a dowel, and it may come to that. But I’d prefer to saw the hole because I want to make several of these, so fewer steps is better (hole saw vs. drill, turn, glue). Also, it seems like it would be hard to avoid getting glue on the walls of the slot when inserting the dowel.
View scottb's profile
scottb
3648 posts in 2524 days
#9 posted 896 days ago
could try to “modify” a plug cutter. either by grinding down each leg one at a time, or possibly with diamond files while it’s spinning slowly on the drill press or lathe. might be a dremel tool thin enough too?
-- I am always doing what I cannot do yet, in order to learn how to do it. - Van Gogh -- http://blanchardcreative.etsy.com -- http://snbcreative.wordpress.com/
View Edziu's profile
Edziu
144 posts in 1248 days
#10 posted 896 days ago
I’m not positive, but I think this would work. The slot it leaves might be a tad big, but it wouldn’t be awful sloppy like a plug maker http://www.rockler.com/product.cfm?page=2354&filter=screw%20remover
3808 posts in 2218 days
#11 posted 896 days ago
These might work.
http://www.woodcraft.com/Product/2000983/2010/Screw-Extractor-516.aspx
View rance's profile
rance
3865 posts in 1357 days
#12 posted 896 days ago
Maybe silver-solder an older inking nib to a 0.222” metal dowel, nib pointing up. Leave the butt end sticking out past the metal dowel. Shape the butt end into a cutter like:
Run it in a drill press real fast and take light cuts.
TopamaxSurvivor
13179 posts in 1873 days
#13 posted 896 days ago
Dependiing on what you are trying to cut and how hard it is, a .223 Remington case chucked up in a drill press with teeth filed on it should cut about what you want. The cheap ammo even has steel casings.
-- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence
Peter Oxley
#14 posted 895 days ago
Great ideas, everyone! I’m going to give a few of them a try and I’ll let you know how it works out.
