| Forum topic by BobGlenn | posted 2254 days ago | 56723 views | 4 times favorited | 34 replies | ![]() |
2254 days ago |
———————————————————————————————————————— Now lets say the customer wanted just the shelf. So the shelf would be removed. Maybe some of the shelves would be 8”-12” wide x maybe 2-3” thick x 18-24” long. Would use a keyhole system, say with 3 keyholes into a 2×4 should provide enough support yet quick and removable for a quick sale?????? Any better ideas -- Welcome to Northern Ind. Coffe Pot Is On |
34 replies so far
#1 posted 2253 days ago |
Bob, One expensive method I’ve seen for “permanently” hanging floating shelves is to weld 3/8” metal dowel rods perpendicular to a steel strip. The steel strip is then screwed into the wall and the floating shelf slides right onto the metal dowels with the dowels going into the recess of the shelf. Since you’re just hanging these shelves temporarily, maybe you could mimic the same thing using wooden dowels glued into one inch thick lumber. Drill 3/8” holes into the one inch thick wood and put the dowels into the holes with glue. Screw the 1” wood into your display case or whatever you’re using. Then, all you have to do is slide the floating shelves on and off the pegs. -- There are three types of people in the world, those who can count and those who can't! |
#2 posted 2253 days ago |
I saw a plan for making shelves out of hollow core doors. You screw a board that fits between the two outside panels of the door into the studs of the wall. You then slide the door that has had one side ripped off. So if you wanted 12” shelves use a 24” door. You then screw the ply into the top and bottom of the wood piece. My son bought some shelves from Ikea and they were similar design. The shelf just floats out into space with no visible support. -- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware karson_morrison@bigfoot.com † |
#3 posted 2253 days ago |
Bob, Come to think about it, you might not need to glue the dowels into the wood if you want to use different sized dowels for different sized shelves. The dowels would be removable. -- There are three types of people in the world, those who can count and those who can't! |
#4 posted 2253 days ago |
We are getting somewhere with the inputs. Another idea floating round would be a dovetail in the backside of shelf, with a cleat mounted to the wall. Problem with that if you had a 14” shelf it would take 28” of space to mount it. Cost factor is the main consideration as to keep the price of the shelf affordable for the customer. -- Welcome to Northern Ind. Coffe Pot Is On |
#5 posted 2253 days ago |
Woodsmith had a article about floating shelves. Basically if the shelf is 24” long, attach a 20” piece of angle iron to the wall into the 2×4s. Then the shelf was made with a small slit, just big enough to slide over the metal. Now, when you sell a shelf you can just slide it off and another one on as soon as you are ready. -- Making sawdust is what I do best |
#6 posted 2251 days ago |
When you pull the shelf off at the sale don’t you also need a wall fastener to be sold with it? You’re basically making a torsion box with one side recessed for what gets mounted to the wall. I think Wood magazine had an article about using moulding to make a 3 sided box, routing a 1/4” groove near the top for a piece of glass, putting a small lamp inside for a display shelf. I like the angle iron idea as it allows for thinner shelves. -- No piece is cut too short. It was meant for a smaller project. |
#7 posted 2251 days ago |
How strong can you really make these floating shelves? A friend of mine would like to have some to display books, but I’m not sure that a floating shelf could handle the weight of a full load of books. -- JP, Shelbyville, KY |
#8 posted 2250 days ago |
JP, Other contributors Here is a cost effective idea floating around in my head. One could take a board say for example: Figures might not be right, doing this in my head Step 1.) Just lay a level on one when you go to mount the second on the wall. Step 2.) Step3.) This way with floating 2X2 FINGER PRESS FIT BOARDS, one adjust these to match the dowells on the wall, right & left, one could mass produce these and still be cost effective. Sounds complicated but not…......time, and effort would be mimninal. Strength not for sure how much, books?? The proto type in my head says it would work…...... Shelfs beyond 32” would require more dowells, and more floating 2×2 -- Welcome to Northern Ind. Coffe Pot Is On |
#9 posted 2245 days ago |
I have a display case on a wall, which is held by two part hangers. If you are using shelves of a full 1.5” width, I think these might work, as long as the shelf was no more than 6-8” wide. Too much weight though, might pull the hangers out of the batten, or the batten from the wall. Inside a case, I prefer library-hanging strip, which can be recessed into the sides of the casework. The small metal clips that engage in the strip are very strong for their size, and I have used them with solid mahogany shelves up to 5’ 10” long, without central supports. Here is a link to somthing similar, for your wall-shelf. This firm also supplies library strip. HTH -- Working fast helps you to arrive at your mistakes in spectacular fashion. (Me 2009!) |
#10 posted 852 days ago |
Hi, I just registered here. I have a log home, and am planning on putting up some shelves made of 2 inch thick rough sawn pine, with bark still attached on one edge. The only requirement is they be strong enough to be fully loaded with textbooks. My plan is to make floating shelves using 1/2” by 10” lag bolts. These go for about $1.50 in the big chain hardware stores. I’ll drill guide holes into studs and screw in the lag bolts to the a depth of about 3”, then cut the heads off the bolts. Then the 2” thick planks will be edge drilled at the right spots and I’ll slide them onto the headless bolts. The bolts are strong enough that I figure I can put one every other stud (i.e. every 32”). (I’ll be testing out weight capacity first though) To make it more interesting, I’ve decided that instead of just cutting off the heads after screwing the bolts in, I’ll grind parallel flat spots on opposite sides of the shaft of the bolts right below the head, cut the heads off, and insert using a wrench on the ground flat spots. This will make removal easier if ever desired. I’ve already built a jig around a bench grinder that does a nice job of grinding the flat spots. Anyone see any problems with this approach? |
#11 posted 851 days ago |
Here are some pics of the apparatus I used to grinding flat spots on my lag bolts for turning with a wrench, and the finished results (the finished lag bolts that is – shelves aren’t up yet). Bench grinder with wooden guide (sorry, this pic came out upside down): Block of wood to hold bolt for grinding: Grinding: 1/2” by 10” lag bolt, original and modified: Close up of modification: I could have done this a lot simpler with large hanger bolts, but only ones I could find online were smaller and much more expensive. |
#12 posted 831 days ago |
Well, after much ado about crafting my own hardware from lag bolts, I decided that though I loved the results, it was far too labor intensive, and I went with 10 inch by 1/2 inch hanger bolts, which cost about $2 each for a box of 100. I’m putting up shelves throughout the house, but still more than I need, but maybe I can get rid of rest on eBay. Anyway, first shelf is up, pictured below, with hanger bolts for second shelf above. The shelf is more than strong enough to hold anything I’ll put on it. I’m 6’2”, and can hang my full body weight from two of the hanger bolts. (Michter’s Single Barrel Straight Rye, for the curious) |
#13 posted 831 days ago |
The floating shelf cleats from lee valley are great , i have used them in the past. u can either make the shelf in two halves and dado the two halves and glue them together or bore a hole in a completed shelf that if I remember correctlty has to be about an inch thck due to the size of the cleats, and they can hold a fairly large load. -- rob, ont,canada |
#14 posted 831 days ago |
I checked out the Lee Valley floating shelf hardware ( http://www.leevalley.com/us/hardware/page.aspx?p=51933 ), but I can’t see any advantage over plain old hanger bolts. It’s prettier, but you never see it. It’s, at best, 3 times the cost of hanger bolts, and can’t be nearly as strong. |
#15 posted 831 days ago |
not sure how to delete my post, sorry |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1536 |
3554 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
